Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Power Steering Pulley Install
Old 09-20-2007, 07:09 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is online now
Just a little tip for installing a power steering pulley. Use the puller tool that you can rent from Autozone or buy from Harbor Freight for $20. When you go to install it, you will need to hold the pulley itself rather than the arbor while turning the nut to install the pulley otherwise the arbor will back out and you won't get it put on. Just figured that one out last night.
Old 11-17-2007, 04:03 PM
kyles609's Avatar
kyles609
kyles609 is offline
Install Pulley
I have to replace my PS Pulley. I got the old one off and bought a new one. I understand the concept of installing it with the tool (bolt/nut), but I am unable to thread an 8mm bolt into the shaft. I looked at a PS pump for my 96 Explorer at the parts store and that was the size bolt that came with it to do the install. However I am unable to get anything to thread. When I look in it with a mirror/light Its hard to see threads, mostly just rust. I tried cleaner and a wire brush. Could it be possible that it is too rusted inside there that I will be unable to thread it and have to replace the whole pump in order to get this pulley back on?
If your wondering. I hit a deer and somehow in the process the pulley shattered. I have everything fixed but this to get it back on the road.
Thanks for your help.
Old 11-18-2007, 12:40 PM
blue beast's Avatar
blue beast
blue beast is offline
Use a thread tap or chaser and see if it cleans up, It could be some protein matter
from the deer!! Another good tip is to heat the pulley up and use keyboard duster
to freeze(shrink) the shaft, turn the can upside down so the freon comes out of
course while wearing thick gloves since you run the risk of both burning and freezing
yourself!!
mxer0022
09-13-2016 09:58 PM
tommyblack
2004 - 2008 F150
01-08-2015 12:02 PM
SaturnSky11
1983 - 2012 Ranger & B-Series
05-29-2014 07:32 PM
jeff14346
17
03-23-2013 05:42 PM
Marky48170
07-29-2012 09:00 AM
Quick Reply: Power Steering Pulley Install
