FMX Transmission Bellhousing
Old 08-30-2000, 10:56 PM
fastredford's Avatar
fastredford
fastredford is offline
Is there a bellhousing available to run a FMX automatic with a 390? I have run them with 351C and they work fine and take quite a bit of abuse. I just got one free from a friend but it has the 351W bellhousing.
Old 08-31-2000, 12:12 AM
3179crew's Avatar
3179crew
3179crew is offline
YES.....I used to run the FMX behind a 390 in a roundy round Galaxie. most of the c*#@y guys couldn't figure out how we push started an automatic car!!!
L. Edmundson
31 crewcab
35 pick up
72 F-100 lowrider
79 F-150 crewcab (custom built)
Old 08-31-2000, 08:29 AM
fastredford
Thanks on the info. Any idea what year or make I should look for at the wrecking yards to find one?
Trucks or cars?
Thanks again.
Old 09-02-2000, 06:06 AM
jowilker's Avatar
jowilker
jowilker is offline
Jeff, You will either need to find one out at a salvage yard or look in the 58-66 era cars and trucks with a FE 352/390 in it. You can tell by the shift indicater, it will have a green dot on it.
That tranny has a little different shifting pattern than most so get the indicater with the tranny. I have a 66 F100 with one in it, and I receintly had it rebuilt.
John
jowilker@nc.freei.net
66 F100s
In the still cool hours of the night, you can hear chevys rusting away.
Old 11-28-2002, 12:40 PM
warhorse 67's Avatar
warhorse 67
warhorse 67 is offline
to fastredford i just recived a fmx with a 390 bell housing if you would like to swap.e-mail me at warhorse67(No Email Addresses In Posts!)
Old 11-28-2002, 04:36 PM
jowilker's Avatar
jowilker
jowilker is offline
hoss, that post is 2 years old.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member 0004 since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old 11-28-2002, 08:02 PM
BigJake86's Avatar
BigJake86
BigJake86 is offline
Old 05-02-2010, 07:43 PM
driftonin's Avatar
driftonin
driftonin is offline
I need a fmx 390 bellhousing
Old 05-02-2010, 11:32 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,656 Likes on 1,352 Posts
Feel free to start a new thread for something like this. The FMX ran '67 to '79, so lots of 360 equipped PU's and other FE vehicles could have the part you need. Read more on this thread, which includes a link with info:
https://www.ford-trucks.com/forums/9...ml#post8844083
Old 05-03-2010, 03:36 AM
jowilker's Avatar
jowilker
jowilker is offline
Would the FMX have a different bell from the C-O-M? I know C-O-M goes back to 65 in the trucks.
The FMX may have been offered through 79 but the FE was not offered past 76.
John
Old 05-03-2010, 03:48 PM
85e150's Avatar
85e150
Post 8 here indicates they are close enough to adapt. He's talking FMX trans to Ford-o-matic bell to fit a Y block.
http://www.460ford.com/forum/showthread.php?t=142323
A bit of a search to find this, and it requires some fiddling. I would look for the FMX bell and be done with it. Millions (maybe) served, they should not be hard to find.
Old 05-04-2010, 05:32 PM
driftonin's Avatar
driftonin
Thats nice
Thanks, the FMX as I said we pulled it out it wasnt an FMX but a Nice C6
Looks as if the seals had just been replaced, This kit looks good gona get one a C6 behind a Y Block, hmm who woulda thunk it.
Thanks Richard
Old 05-04-2010, 08:08 PM
jowilker's Avatar
jowilker
jowilker is offline
You have a C6 that will bolt up to a Y block?????? A one piece case C6?
John
Old 05-04-2010, 08:33 PM
driftonin's Avatar
driftonin
No, but with the kit from, Bendtsen’s
We have finally put a Ford AOD transmission on these motors with no block modifications, and only a small case modification done at home!
This adapter kit will allow you to bolt ANY small block Ford transmission to these motors! C4, C6, AOD, E4OD, T5 manual trans, etc. This kit was mainly developed to allow Y-block owners to bolt popular automatic overdrive transmissions to these motors without butchering the block or case. If you only want to bolt on a C4 trans, then there are cheaper alternatives. Unlike other kits, we give you the flexibility to change the transmission type at any time. With that in mind, who's kit is really high priced? My kit is priced within $170.00 of the kit that only lets you put a C4 trans on your motor. I've been a transmission rebuilder for over 30 years, and I can say that the Ford cast Iron transmission ( with modifications ) is a far better transmission than the C4. The only advantage the C4 has is that it is smaller and lighter. Switching to a C4 transmission seems like nothing more than an expensive lateral move. Do yourself a favor and reduce your engine RPM's. Your motor will reward you by lasting twice as long. The gear ratio's in the AOD are also much better than the C4 trans. We have two
robert_allen
06-28-2018 02:51 PM
Nathan Koeppe
04-13-2017 08:46 AM
351WRanger
15
01-18-2017 12:27 PM
lance65
WTB - Parts & other
05-27-2014 09:28 PM
occupant
General Automotive Discussion
16
10-16-2011 07:00 PM
Quick Reply: FMX Transmission Bellhousing
