Another temperature gauge problem
My 1996 F-150 with the 6 cyl 4.9 engine has a problem with the coolant gauge. The gauge needle rests just below the "C" but when the other gauges "kick in" after the engine starts it goes backward all the way to the peg and never moves from that spot as long and the engine is running. I took the instrument cluster out (a real adventure) and checked the gauge by jumpering a 1.5 volt battery to the contacts. The gauge works fine. It goes all the way left or right depending on how the 1.5 volt battery is jumpered to it. The coolant sensor, located just above the water pump, reads about 36 kilohms with the engine cold and about 2.6 kilohms with the engine hot so it seems to be functioning OK. Disconnecting the sensor while the engine is running produces a "fluttering" sound from somewhere on the engine and goes away when the sensor is reconnected so it seems to be connecting with the electronics with no problem. Is there another sensor somewhere on the engine that I am missing or is it something else altogether?? I realize that the Ford gauges leave something to be desired but it just bugs the dickens out of me to see that particular one not functioning. Any help from out there would be appreciated.
Thanks for the replys. I found the sensor and it checks OK. Had my wife turn on the gauges while I quickly grounded the wire going to the sensor and had no response on the gauge. Looks like there is a wiring or connection problem somewhere. Any recommendations for an after market/under the dash meter of some kind?
I hooked a wiring toner (we use these to trace data wires in buildings) to the sensor end and traced the signal through the harness and past the firewall into the cab. It looks like the connections are fine. I noticed some diodes tacked onto the flexible wiring sheets on the back of the instrument cluster when I had it out. Is there a schematic of the instrument cluster available anywhere?? Can't find one in the Haynes manual. Still trying to get the gauge to function.
KJNDIVER
04-12-2015 06:58 PM
