Supercharger Stats (M-6066-F105)
I am currently looking at putting a Ford Racing Supercharger (M-6066-F105) on my 06' F-150 SCab 4x4 XLT 5.4L 3v. Has anyone added one of these? The listed Hp and torque added is 160. Does anyone know if this is at the wheels or at the crank? Do you recommend any other additions once the supercharger has been added?
Matt
Matt
on
Those numbers are at the crank. Question, is the supercharger kit different than buying it from Whipple directly? If not, then if it were me I wouldn't pay the extra $300 just to have Ford's name on the box. I recommend after installation you take it to a good custom tuner with a tuner who can give you more throttle response with safe a/f ratios.
well it says in the tech notes @ the rear wheels
M-6066-F105**Black Wrinkle Finish
Fits all 2005-2006 F-150 with 5.4L 3-valve engine
Complete kit contains all hardware and detailed instructions
Intercooled system
Black wrinkle finish
Premium fuel only
Designed for use with factory throttle body
95mm mass air meter
Due to multiple calibrations, online registration is required to receive Pro-Cal tool after purchase
Pro-Cal tool voucher included with kit
Simple bolt-on rear wheel increase of approximately 160 horsepower and 160 ft./lbs. of torque
Installation of this kit will void your new vehicle powertrain warranty
Designed by Ford Racing and Whipple engineers
E.O. #D-231-24
Engine calibrations are developed and supported for U.S. and Canadian vehicles only
NOTE: Superchargers are built to order. Please allow 7 days for assembly.
Intercooled system
Premium fuel only
95mm mass air meter
E.O. #D-231-24
I have the Roush I/C supercharger on mine I make great power heres a list of my power mods
410RWHP/456RWTQ
Roush I/C Supercharger
2lb lower pulley
XCAL2 "Dyno tuned by Mike Troyer"
Pacesetter Long tube headers
Magnaflow hi-flow cats & Xpipe
Dual Magnaflow
E-fans
GMS Coil Packs
Blower at stiegemeier for stage 4 port
410RWHP/456RWTQ
2lb lower pulley
Dual Magnaflow
E-fans
GMS Coil Packs
kingdomflight
16
02-18-2017 12:50 AM
Pete B
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
01-20-2006 07:44 PM
