302 running rich and pinging
Truck info 94 F150 302 maf (factory setup) e4od . Stock timming seting (Up or down does not effect pinging much)
Problems . Thought I got a bad batch of gas was pinging bad and doggy. I added lucas fuel aditive and helped. I was going to was truck and saw the exhaust was soot black . And the pinging is still ther after 3 rd tank.
SO.
The codes I pulled where 12 ,13 Or /-// ,/-//,---- /-///,/-// used Fordfuel injection.com .
The rich could be fuel presure reg right. (did search) Truck has less than 10000 miles on new MDS CAP Rotor ,MDScoil and ford racing wires . I will chance the Motocraft copper core plugs as they have 20000 miles.
So what about the pinging ??? any ideas , I play with these trucka all time and this is the first to give me hassle like this. I have all new electrical sensors on shelf for throtle body ETC.(eBay score) .
Any help would be appriecated.
SO.
Has 40000 on motor new Ford unit. Pings on hills at higher RPM but is getting worse since last week .
As for vacuum leak tried the propane trick on em and remove checked them already
Wires are near new and routed so none near touch . And there are no arcs after dark and its been humid enough it should show. Thanks guys. It may be next week end before I get everything checked.
I just replaced filter Yesterday and It still dose on both tanks. The fuel check while running might be fun . I checked fuel on gas at fuel pressure vacuum line . removed and reinstalled all vac line look fine good condition. Tomarow I try to get some cleaner and gasket for EGR . And clean MAF ERG and IAC
ham-n-swiss
06-03-2009 03:59 PM
opeterson
03-26-2006 05:20 PM
