Door sticker tranny code Q ??
Old 08-03-2007, 09:08 AM
Scott109's Avatar
Scott109
Scott109 is offline
Hi everyone, My 2006 F-150 XLT 4X4 has tranny code Q. I did not see that letter on the door sticker decoder on this site. Does anyone know what tranny this is? Or could point me in the right direction to find it? Thanks!
Old 08-03-2007, 10:01 AM
Scott109's Avatar
Scott109
Scott109 is offline
Never mind, I found it.
Model: 4R75E
Type: Four speed, Rear wheel drive, and 75(x10)lbs of torque
Years: '04-'07 F-150
Engines: 5.4L
Display: PRN(D)21 w/ overdrive lockout switch
Fluid: Mercon V
Ratios:
1st 2.84:1
2nd 1.55:1
3rd 1.00:1
4th 0.70:1
Reverse 2.32:1
Trans code: B ('04-'05), Q ('06+), F ('06+ Mark LT)
The following users liked this post:
Old 08-03-2007, 10:08 AM
KevinM's Avatar
KevinM
KevinM is offline
Q= 4-speed automatic, 4R75E
Electronically Controlled 4-speed Wide-ratio Automatic Overdrive Transmission (E-Series and F-150)
Transmission code 4R75E
Major features and benefits:
+Robust drive gear and friction materials
+Torque converter provides impressive launch performance and efficiency
+A turbine speed sensor produces improved transmission control and provides the basis
for the fully electronic shift scheduling
+Microprocessor speed improves responsiveness and precision of the control system
+"Smart" fully electronic shift scheduling coupled with the Electronic Throttle Control (ETC) technology calculates torque in the next gear and regulates shift points based on vehicle's projected performance in the next gear
+Overdrive lowers engine rpm at highway speeds, contributing to improved fuel economy
+Adaptive pressure control maintains consistent shift response and feel over time
+Sealed case with lifetime transmission fluid
The following 2 users liked this post by KevinM:
rlacan71
09-09-2014 09:47 AM
cole96
02-02-2009 04:47 AM
handyfiremedic
01-18-2008 08:39 PM
CMOS
2004 - 2008 F150
12-20-2005 04:23 PM
renoduckman
1983 - 2012 Ranger & B-Series
10-28-2004 07:40 PM
Quick Reply: Door sticker tranny code Q ??
