2008 SD Differences?
Yes.
From https://www.ford-trucks.com/specs/20...uper-duty.html
Every 2008 Super Duty frame now has a new front stub designed with safety in mind. By lowering the frame horns seven inches at the front, the new frame meets vehicle compatibility standards without the need for add-on components. The new design also improves cooling and provides a solid foundation for the hydroformed body structure. Every Super Duty frame is e-coated for improved corrosion resistance.
The newly designed leaf-spring rear suspension delivers superior ride and handling in all load situations. The eight-inch longer springs attach farther forward on the frame giving the vehicle more balance and better control. New damper tuning further improves Super Duty’s confident feel on the road.
The Super Duty is the first truck in the industry to use a high-strength steel front body structure. The patented structure, made up of two side rails that are welded to the bulkhead and frame, not only serves to create a very rigid foundation, the system’s modular construction eases assembly and delivers higher quality and better fit and finish.
The revised frame and front-end structure enables a Front Gross Axle Weight Rating (FGAWR) increase to 5,250 pounds on 4x2 F-250 and F-350 trucks.
Frozen001
1999 to 2016 Super Duty
10-04-2016 07:14 AM
