Sponsored by: Real Truck
reverse sensor
Old Aug 1, 2007 | 11:23 AM
2003V10F250's Avatar
2003V10F250
reverse sensor
I have a 2003 SD with the V-10 and reverse sensor. The sensor isn't working properly. When I put the truck in reverse the off light for the sensor comes on right away and stays that way no matter what gear, drive selection I am in unless I press the button on the dash. Has anyone else had this issue and if so any ideas as to what to check? I went and looked at the wires on the back of the bumper where the sensors are located and didn't find anything loose or amiss there that I can tell. Does anyone know what to do the fix the system quickly?
Thanks in advance.
Here is a recent picture of our trucks at the Bloomsberg Jamboree last month.
Old Aug 1, 2007 | 12:56 PM
msgtg's Avatar
msgtg
I'd suggest doing a search on the issue. I've read tons of different threads in various forums here on the FTE. Some are in the X Forums, some here in the SD and others in the F-150 Forums that I've seen.
