Sponsored by: Real Truck
2008 SD Differences?
Old Jul 31, 2007 | 06:43 PM
GKDave's Avatar
GKDave
Are there any significant changes to the chassis on the 2008 F350 SD vs. the 2006 or 2007 SD? I am getting a new 2008 SD, as a repalcement for my 2006, and the chassis looks to be the same. Am I wrong?
Dave
Old Jul 31, 2007 | 07:29 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes.
From https://www.ford-trucks.com/specs/20...uper-duty.html
Every 2008 Super Duty frame now has a new front stub designed with safety in mind. By lowering the frame horns seven inches at the front, the new frame meets vehicle compatibility standards without the need for add-on components. The new design also improves cooling and provides a solid foundation for the hydroformed body structure. Every Super Duty frame is e-coated for improved corrosion resistance.
The newly designed leaf-spring rear suspension delivers superior ride and handling in all load situations. The eight-inch longer springs attach farther forward on the frame giving the vehicle more balance and better control. New damper tuning further improves Super Duty’s confident feel on the road.
The Super Duty is the first truck in the industry to use a high-strength steel front body structure. The patented structure, made up of two side rails that are welded to the bulkhead and frame, not only serves to create a very rigid foundation, the system’s modular construction eases assembly and delivers higher quality and better fit and finish.
The revised frame and front-end structure enables a Front Gross Axle Weight Rating (FGAWR) increase to 5,250 pounds on 4x2 F-250 and F-350 trucks.
Old Jul 31, 2007 | 09:44 PM
ReAX's Avatar
ReAX
They probably made the wiring harnesses and frame rails just as ugly and up side down as they did the body. So I wouldn't count on many parts crossing over the the 08.
Old Aug 1, 2007 | 07:37 AM
Biggziff's Avatar
Biggziff
Thanks for that helpful and enlightening post.
Old Aug 1, 2007 | 10:22 AM
ReAX's Avatar
ReAX
Well the less opinionated version is when they change the body style that drastically, they change everything enough that the previous years part will not fit.
Frozen001
Oct 4, 2016 07:14 AM
dlcleav
2004 - 2008 F150
Sep 13, 2008 01:52 PM
pilotshot
6.4L Power Stroke Diesel
Mar 28, 2007 11:01 PM
mmusky1
Feb 22, 2007 12:22 AM
