Washington Chapter Washington Chapter
Join Chapter, Leader: Yahiko
Good transmission shop
Old 07-22-2007, 09:34 PM
ryansmo's Avatar
ryansmo
ryansmo is offline
I bought a 2001 PSD auto about 6 weeks ago and when I am hauling a heavy load or pulling a trailer my transmission doesn't like to shift out of 2nd gear once it gets hot. By dumb luck I discovered if I stop, shift into reverse (which seems to slip) and goose my throttle, it seems to straighten the mess out somehow. The truck has 4" Magnaflow turbo-back exhaust and Edge Juice w/ Attitude. It now has about 45,000 miles and I want to get the tranny looked at because I plan on keeping this truck for a while. I live in the Issaquah area and was wondering if any of you have had similar issues or know of a good transmission shop in my area that has diesel know-how. I appreciate the advice.
Old 07-22-2007, 10:11 PM
Ford_Six's Avatar
Ford_Six
Ford_Six is offline
A tranny shop will just want to pull and swap or rebuild. Try changing the fluid, and add an inline filter to catch all the junk that will flush out. I made one from a remote oil filter kit with a standard Ford oil filter, and it worked great. As an added bonus, it did increase the capacity by about a quart as well.
Also, add a cooler, or if there is one already, make sure it's in good shape and is mounted where it gets enough airflow.
Check out the transmission forum for advice also.
Old 07-23-2007, 05:21 PM
Parrsboro's Avatar
Parrsboro
Parrsboro is offline
I have had good luck at Kings transmission, i use the one in kent, there is one in renton too not sure where all of there locations are.
But the few times i have needed to go to them, they dont mind finding the problem first , swapping out etc is always a later choice.
Old 07-25-2007, 10:25 PM
spidertoy's Avatar
spidertoy
spidertoy is offline
I took the wifes to Puget Park Transmission and they did a GOOD job, gave me all the options before just going for the gusto, you know
lanidan
05-14-2015 05:42 PM
Powerstroked XLT
N. California Chapter
07-22-2014 02:11 AM
Paul Moody
03-05-2012 07:10 AM
Marky48170
Michigan Chapter
09-26-2011 10:19 AM
Marneaus
1983 - 2012 Ranger & B-Series
07-26-2011 01:56 PM
Quick Reply: Good transmission shop
