Blowing ATM-10 Fuse Daily!
Okay, I need help on this one - has anyone else experienced blowing a fuse all the time? Got a 2002 F250 xlt. Never had any problems with it, but now my instrument panel goes out and the ATM-10 fuse blows constantly. It seems to do it only after starting the truck and putting it in reverse?!? Though today it did it when I put it in drive. . .I know there's a short that I have to find, but was wondering if anyone else experienced this? And maybe where to start looking? Steering column maybe? HELP!
Thanks,
Kurt
Thanks,
Kurt
I don't know what ATM-10 is but Fuse 10 is A/C clutch.
The fuses are coded as follows.
Fuse/Relay Location Fuse Amp Rating Passenger Compartment Fuse Panel Description
1 15A* Adjustable pedals
2 20A* Power point - floor console
3 20A* Power point – 3rd row
4 20A* Power point - instrument panel
5 20A* Power point - right rear quarter
6 20A* Trailer tow turn/stop relay
7 30A* High beam headlamps / Flash to pass
8 — Not used
9 20A* Heated mirrors
10 10A* A/C clutch
11 20A* Radio (main)
12 20A* Cigar lighter / OBD II
13 5A* Power mirrors/switches
14 15A* Daytime running lamps
15 10A* Driver’s seat module memory
16 15A* Rear seat controller
17 15A* Exterior lamps
18 20A* Turn lamps/Brake on-off switch (high)
19 10A* Body security module/4x4 module
20 — Not used
21 25A* Rear wiper motor
22 20A* Engine control
23 20A* Engine control
24 15A* Air suspension
25 10A* 4-Wheel Anti-Lock Brake System (4WABS) module
26 10A* Airbags
27 15A* Ignition switch Run feed
28 10A* EATC module module/Front blower relay coil
29 10A* Customer access
30 15A* Highbeam headlamps
31 15A* Clutch interlock switch
32 5A* Radio (start)
33 15A* Front wiper
34 10A* Brake on-off switch
35 10A* Instrument cluster
36 10A* PCM Keep-Alive
37 15A* Horn
38 20A* Trailer tow park lamps and backup lamps
39 — Not used
40 20A* Fuel pump
41 10A* Instrument cluster
42 15A* Delayed accessory
43 10A* Fog lamps
44 10A* PATS module, transceiver
45 10A* Ignition switch Run/ Start feed
46 10A* Left-hand lowbeam
47 10A* Right-hand lowbeam
48 10A* Rear wiper motor
101 30A** Trailer tow electric brake
102 30A** Door locks/Body security module
103 50A** Ignition switch
104 40A** Heated backlite
105 30A** Injector driver module
106 30A** Front wiper main
107 40A** Front blower motor
108 40A** Auxiliary blower motor
109 30A** Heated seats
110 50A** Ignition switch
111 30A** 4WD/Shift on the fly
112 30A** Left-hand power seats
113 30A** Starter motor
114 30A** Right-hand power seats
115 20A** Trailer tow battery charge
116 30A** Ignition switch
601 30A CB Door window motors
602 60A** 4-Wheel Anti-Lock Brake System (4WABS) module
210 — Not used
8 — Not used
10 10A* A/C clutch
20 — Not used
26 10A* Airbags
33 15A* Front wiper
37 15A* Horn
39 — Not used
40 20A* Fuel pump
43 10A* Fog lamps
210 — Not used
I don't think its the transmission shift lever harness if it's actually F2.41 blowing. The O/D cancel switch is on F2.45. However, F2.45 DOES help run the gauge cluster. Is it possible you're actually blowing this fuse?
Looking at the drawings for the 02 Superduty, I see that F2.41 goes to the cluster, but it's just a switch-through for the courtesy lamp circuit via a relay and does nothing that is evident from the schematic to operate the cluster itself.
If it is actually F2.41 blowing and the diagrams are correct, you've got an intermittent short in the courtesy lamp circuit.
Steve
Steve
fordman8
12-28-2008 07:14 PM
fireeater91
01-26-2008 08:17 AM
