Transmission Cooler Hd 40,000 Gvw Tow Towing Tru-cool
tru cool tranny coolers good?? looking for a real good trans cooler for my 2001 f350 7.3. what do u think?? will be towing full size ford f150 several times per month. ebay has one here:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7999761185
thanks. rob.
thanks. rob.
I have had one on my truck for quite awhile...drive in 100+ temps regularly throughout the southwest...never see 200 degree temps anymore with a 35' 5er or my car trailer. If you do much slow speed, desert crawling while pulling a load, get a unit with a fan. I had to add a fan on mine so I take my equipment out to my turquoise claims.
I had an old one (electric fan) from a hot rod I built years ago...don't know the name of it. You won't need a fan unless you have to crawl (two-three miles per hour, like on steep mountain passes in the desert on dirt roads) If you are highway driving the TruCool by itself will serve you well. The B&M with a fan is a good unit too...check out Summit Racing for other choices.
I don't believe Hayden does make one with a fan...here is the biggest, fanned cooler, that B&M sells:
http://store.summitracing.com/egnsea...5&autoview=sku
plgebbia
20
03-31-2011 11:38 AM
RDave
07-14-2007 07:29 AM
imlowr2
31
05-05-2005 03:08 PM
