A Cheaper Wiper Motor
This past spring I came up with a cheaper solution to replacing the 12V wiper motor and switch on my son's 55 F100. Instead of buying a motor and switch combination from the common sources (Mid-Fifty, Sacramento Vintage, Dennis Carpenter) I mated a surplus motor from a 2000-01 Saturn to a Cole Hersee Switch. The moter is listed at a number of surplus houses for less that $20. The places that I found that had this motor are:
http://www.halted.com
http://www.mpja.com/productview.asp?product=15007+MD
http://www.meci.com/product_info.php/cPath/360_221/products_id/4200578
This is a dynamically braked motor (stops at a specific location instead of coasting to a stop). Because of this is requires a switch set up for dynamic braking. The switch that is used for this is a Cole Hersee 75228-04. I found the switch at Redden Marine for less than $15.
http://www.reddenmarine.com/site/new-detail.cfm?id=CHR7522804
The mounting holes for the motor are a little different than the motor that came on my truck, so I cut a 1/8" thick piece of steel and welded it to the mounting plate that was already there. This allowed me to mount the new motor in the correct position. It was then a simple matter of modifying the wiper arm assembly from the '55 to attach to the new motor arm.
A mounting diagram and wiring digram are hopefully shown at the end of this post (If not they will be posted in my gallery). Unfortunately I do not have any pictures of this assembly but it works well.
We were also able to modify the shaft of the switch so that we could mount an original Ford ****.
For a little under $40 we were able to get a new wiper motor and switch into our '55.
Motor Mounting Diagram<o>></o>>
<!--[if gte vml 1]><v:shapetype id="_x0000_t75" coordsize="21600,21600" o:spt="75" oreferrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"> <v:stroke joinstyle="miter"/> <v:formulas> <v:f eqn="if lineDrawn pixelLineWidth 0"/> <v:f eqn="sum @0 1 0"/> <v:f eqn="sum 0 0 @1"/> <v:f eqn="prod @2 1 2"/> <v:f eqn="prod @3 21600 pixelWidth"/> <v:f eqn="prod @3 21600 pixelHeight"/> <v:f eqn="sum @0 0 1"/> <v:f eqn="prod @6 1 2"/> <v:f eqn="prod @7 21600 pixelWidth"/> <v:f eqn="sum @8 21600 0"/> <v:f eqn="prod @7 21600 pixelHeight"/> <v:f eqn="sum @10 21600 0"/> </v:formulas> <vath o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"/> <o:lock v:ext="edit" aspectratio="t"/> </v:shapetype><v:shape id="_x0000_i1025" type="#_x0000_t75" style='width:358.5pt; height:208.5pt' o:bordertopcolor="this" o:borderleftcolor="this" o:borderbottomcolor="this" o:borderrightcolor="this"> <v:imagedata src="file:///C<img src="http://images.ford-trucks.com/forums/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />OCUME~1SteveLOCALS~1Tempmsohtml1\01clip_image001. png" o:title=""/> <w:bordertop type="single" width="12"/> <w:borderleft type="single" width="12"/> <w:borderbottom type="single" width="12"/> <w:borderright type="single" width="12"/> </v:shape><![endif]--><!--[if !vml]-->[img]file:///C:/DOCUME%7E1/Steve/LOCALS%7E1/Temp/msohtml1/01/clip_image002.jpg[/img]<!--[endif]-->
<o>> </o>>
<!--[if gte vml 1]><v:shape id="_x0000_i1026" type="#_x0000_t75" style='width:302.25pt;height:397.5pt'> <v:imagedata src="file:///C<img src="http://images.ford-trucks.com/forums/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />OCUME~1SteveLOCALS~1Tempmsohtml1\01clip_image003. png" o:title=""/> </v:shape><![endif]--><!--[if !vml]-->[img]file:///C:/DOCUME%7E1/Steve/LOCALS%7E1/Temp/msohtml1/01/clip_image004.jpg[/img]<!--[endif]-->
<o>> </o>>
Wiper motor
I opted for after market, 2 speed wiper motor. The universal "fits all models" had me leery and it turns out I have to "modify the defrost vent on driver side because the motor interferes. It did bolt up to the stock bracket however. I am re-thinking whether I will keep it or not. What alterations did you have to do to the wiper linkage ? Did you mount the wiper swith in stock location, I eneded up moving mine left or original dash location.
Tom
Tom
The wiper motor mounted in the stock location which as I recall is between the fire wall and a dash brace. With this set up there were no interferences with anything else under the dash.
The linkage has a 3/8" "D" hole in it that slips over the shaft of the motor. The motor I used had a knurled tapered shaft. I drilled out the linkage to a 3/8" round hole and simply bolted it to the motor shaft at the correct clocking.
DasCheckers
23
10-24-2016 02:18 PM
FFemt5287
10-20-2007 02:51 PM
