MAJOR Diablo malfunction.... I think
I was hooked up to my 5ver, leaving the jar store for a weekend of fun and frolic and, all of a sudden, my SD 5.4L has no power and its blowing black smoke out the tailpipe like its a Cummins Diesel!!
I call my Ford dealer at 4:00 pm Friday and he says bring it out... I tell him I dont think it will make it. He says call a tow. I unhook the 5ver and make it to the dealership.
They put their computer on it and NOTHING will read. No codes at all. Not even ABS. SO.. I tell them that I have a Diablo chip in it. They say.. "lets take it out". We go to take it out and the ECM is hot to the touch! Once the chip is out, the computer reads the codes fine, the tech reset it and the truck returns to factory specs.
I leave the dealership and my truck runs great all weekend!! No problems since...
My question is.... WHY? and what do I do now?
thanks for any help
thanks for any help
on
The heat is kind of normal, even with a stock computer with no chip. The chip itself is fused to prevent damage problems if it burns out.
There should have been a card with the chip saying to remove the chip in order to read the diagnotics:
"Three: Anytime a diagnostic machine is used, the vehicle's computer needs to be in stock condition. In order for the diagnostic machine to accurately perform its task, it must be able to communicate with the stock computer program. With the chip installed, the diagnostic machine will not be able to do so. Failure to reinstall the stock tuning can result in unnecessayr repairs."
Basically, you can't read codes from the computer when a chip is installed. Usually the only code you'll get is a ROM error code.
Is the chip in now? There could be one of two problems: a) the chip came lose or otherwise had a faulty connection, b) the chip went bad. We've programmed a LOT of chips, so a bad apple rears its ugly head now and then... just had to replace a Superchips Microtuner yesterday because it arrived at the customer's completely dead! For one reason or another your truck is going into an open loop condition.
Here's what I suggest, lightly reclean the connector and reinstall the chip. If all goes well then the connection was the problem (do you have the square Diablo vinyl covering it too?). If it still runs rough, give us a call and we'll gladly replace it.
>dealership.
Just wondering....What did the dealer have to say about modifing the ECU, i.e what effect on you warranty???
>dealership.
Want to confirm
Ken, have been loving my Diablo Delta chip. Hope you don't mind, but wanted to confirm your below statement from earlier in this thread:
So if I have the Diablo Delta, by switching it to the Stock Tune enables the dealer's diagnostic code reader to read the main computer? Want to make sure before I take my truck in to my dealer this weekend for its 15K maintenance checkup; would like to not have to remove the chip if possible.
On a related note, need I be concerned if the dealer wants to update my stock program due to Ford issuing an update to my stock program. My ECU code is HMT1. I have the 87 octane tune and the 91 premium tune on my Diablo Delta chip.
on
Yes, flip it to the stock position. Then disconnect the battery and turn the headlight switch on for about 20-30 minutes to reset the computer.
If the dealer reflashes the computer its really moot because the chip is going to override anything they do when you switch it on. If you want the chip updated to match any flash they do we can do that.
