transmision noise
transmision noise
I have a 95 EB, 302, AODE, the problem I have or should I say have had for a while, its just getting worse. Its when im driving down the road and holding steady on the pedal, when the transmission is shifting up around OD. I get rumbling sound,. kind of like when you hit the rumble strips on the side of the highway. my friends mustang did it and he said most fords do it. the problem is that its getting worse and is lasting longer and doing it more often. check Trans fluids seem to be in check. what else should I be looking for.
transmision noise
[font size="1" color="#FF0000"]LAST EDITED ON 16-Mar-01 AT 04:03 PM (EST)[/font][p]yo!
a pure guess.....
good luck...hope it's an electr thing easily fixed, such as a sticky solenoid in the valve body!
forward clutch friction plates?..at the worse..can only guess at this..see the s www site for ideas:http://www.baumannengineering.com/e4odinf.htm
good luck!
a pure guess.....
good luck!
NorthCarolinaExpy
1997-2006 Expedition & Navigator
05-09-2008 05:36 AM
