AOD in 68 with 302?
AOD in 68 with 302?
I just bought a 68 that has a 302 motor. Will an AOD tranny work? I know it will with the motor, but what about the crossmember? I imagine I will have to have the driveshaft done for the swap.Is there a disadvantage to an AOD vs a C4/C6? I'de like to have an overdrive.Is an AOD strong enough for a truck?
Thanks
DJ
Thanks
DJ
AOD's no problem
DJ, The AOD works very well. Did mine a few years ago.
There are however a number of things you need to take into consideration. Do a search on this sight I may not remember all of them.
The crossmember was moved backwards(four new holes). Custom drive shaft. Custom bracket for the TV cable,(must be adjusted properly. its not a kickdown cable.) Custom bell crank and bracket to make orignal column shifter work(can use floor shifter), and lowered the rear end ratio.
Nice cruiser but takes some work.
Mike
PS. Depending on use AOD is plenty tough, or can be rebuilt with HD parts.
Mike
Mike
Mike
Hi,
I plan on doing the same to my 68. My engine was swapped out before I got it. It came with the 6cly stock. It now has a 351W motor (same tranny bolt pattern as the 302)
A long time ago I built a mustang for my wife. She wanted a 5 speed in it, and the donor car, a 1983 Thunderbird with the 302 had the AOD tranny. I kept the tranny out of that car, along with the flywheel, driveshaft (for the yolks), and the shifter rods.
From what I was told......and read back then( this was 10 years ago or so) is that the 1983-84 Ford AOD trannies are the only AOD trannies that are NOT computer controlled.
I know the one I have isn't, the only wiring that goes to the transmission is the reverse light switch.
Keep that in mind before you get the transmission. I have seen stuff online for a seperate "brain"/computer to run the newer tansmissions on an older non-factory equipped tranny.
Someone correct me if I'm wrong. As it has been several years since I did any research, and things slip my mind.
Just something to think about and see what comes up.
I have also got the factory steering column for mine, that has the column shift for the auto. Will just have to customize for the "overdrive" symbol and location on the readout.
I would like to ditch the clutch pedal once the auto is installed......anyone have comments on that. I know the later years in the Chevy trucks...the whole pedal assembly comes out and bolts in...removing the clutch pedal. Are the fords that way too? I haven't even got as far as looking under the dash to see yet.
Thanks guys......didn't mean to hi-jack the thread.....but its all food for thought for someone thinking of an AOD swap.
Dale
Dale
Mike
Mike
Aod
Hey,
The AOD's were used later than "84" I don't know the year they went to the AODE but my AOD came out of a "87" Lincoln.
The AOD shift indicators only had three positions shown so you don't have to modify your indicator. OD, 2, 1.
The bell crank is a pivot assembly for the shift rod because you can't make a straight shot from the column to the tranny. I got one out of a "87" Ford pickup (I think) and reclocked it to work right.
I saw in a magazine that someone (Lokar maybe?) is making a cable set up for this. Sounds a lot easier than what I did.
Mike
Mike
AOD vendors, there are more. Some good info here in their propaganda:
http://www.transmissioncenter.net/AOD.htm
http://www.becontrols.com/products/aodcat.htm
http://ckperformance.com/ford_aod.html
http://www.tciauto.com/Products/Ford/ford_aod.asp
Good luck.
Good luck.
Hey,
Mike
Mike
http://http://cgi.ebay.com/ebaymotors/Lokar-Ford-AOD-Flexible-Kickdown-Cable-Kit-KD-2AODHT_W0QQitemZ140114727791QQcmdZViewItem
Aod
That cable they call a kickdown cable is actually what Ford calls a "TV" cable (forgot what the TV stands for) but on the Fords it shifts the tranny also. It must be adjusted properly.
It runs between the carb or the gas pedal and the trans.
The cable I was talking about earlier runs between the colmn and the trans to put it in gear. I'll look back in some magazines and see if I can find the article.
88f150302
05-20-2010 01:54 AM
dreadinger
06-20-2008 08:54 PM
superduty06
07-19-2007 09:06 PM
nsaikia
20
11-22-2005 05:19 PM
fine69
12-22-2003 10:50 PM
