C6 to AOD Swap
Don
Some dims here, looks like AOD is shorter.
TCI - TECHNICAL INFORMATION: Transmission Dimensions
Maybe you can contact them for advice, and they sell a trans for $2000 that would probably work....*
Other AOD info.
AOD Transmission from PATC, AOD Transmissions
AOD Performance Products - Baumann Electronic Controls
www.CKPerformance.com
* imo, if you just want to go get a $100 trans and bolt it in, save yourself the trouble.
Also, will your gearing allow your engine to pull the OD? Don't expect an overall fuel savings of 20% just because you get a 20% or so OD....
Put some numbers in here and see what a little taller tire will do.
Novak Conversions - Gearing & Gearing Math for Jeeps
According to the caculator, your tires should be 29 inches & you should be turning 2673 rpm at 65, give it 200 or so for the TC slip, so if you are at 3000, your speed is wrong, ratio is different or tires aren't 29 inchs.
31s would run 2501 + tc slip. That would seem to be the limit for a 302 imo, ymmv.
BTW, the 31s are going to soak up some power unless you can find a skinny, hard tire that tall. Something like AT 31-10.50 x 15s are probably going to eat up all the gas the rpm change saves.
