windshield wiper relay/module part#
Old 04-25-2007, 09:11 AM
ijaraptor's Avatar
ijaraptor
ijaraptor is offline
all wipers aren't working. I have traced the problem to the wiper control module/relay that is behind the right side of glove box. Anyone got a part number for napa/autozone/o'reilly, or is this a dealer only part. Any help is appreciated.
Old 05-01-2007, 09:09 AM
erl_berner's Avatar
erl_berner
erl_berner is offline
Are you sure it's the relay? Mine, and I have read many other articles, about the switch on the turn signal stalk getting corroded. It is fixable by disassembling the switch and cleaning. Do a search on wipers...
Old 05-01-2007, 10:17 AM
Talyn's Avatar
Talyn
Talyn is offline
https://www.ford-trucks.com/forums/s...d.php?t=211828
I wrote a repair guide for it.
Its the same module after 92, but behind the glovebox, not the light switch on the dash.
If its your relay though, high wipers should work.
I'm going to bet its the switch also, mines screwed up too.
I like the old 91 and newer style with the wipers on the dash. to much going on with the newer trucks. I like simple.
That switch was easier to change also.
Old 05-01-2007, 11:53 PM
ijaraptor's Avatar
ijaraptor
Bad Relay
Well I traced it down to the relay for sure. I took apart the washer switch and cleaned it and re dielectric greased it. Was all good up to the relay. Called stealership and they wanted 130.00 for a new one...called local salvage yard, and got one for 6 bucks...it works great and BTW you guys are all great!!
Old 05-02-2007, 09:33 AM
Talyn's Avatar
Talyn
Talyn is offline
I'd tell you dont drop it, but you already installed it.
haha.
They break when you drop them usually.
caseymike143
1999 to 2016 Super Duty
03-23-2011 06:34 PM
tbutt130
04-10-2009 09:01 PM
LoneStarTrucker
13
06-30-2008 08:41 PM
itsn0tus
03-27-2002 06:51 PM
Quick Reply: windshield wiper relay/module part#
