tack wire
Old Apr 29, 2007 | 04:25 PM
pigfarmerdk1's Avatar
pigfarmerdk1
tack wire
Any one know where and what color the tack lead is on a 97 psd. Trying to get my remote start-alarm working. Thanks Dave
Old Apr 29, 2007 | 05:54 PM
ReAX's Avatar
ReAX
1997 Ford F Series Security Information
Constant 12V+ Green/Purple or Yellow Ignition Switch Harness
Starter Red/Light Blue Ignition Switch Harness
Ignition Blue/Green Ignition Switch Harness
Ignition 2 Red/Black Ignition Switch Harness (Heat)
Ignition 3 Black/Green Ignition Switch Harness (AC)
Accessory Gray/Yellow Ignition Switch Harness (Blower Motor)
Tach Blue/Green Multi Coil or White/Pink PCM Passenger's Wheel Well
Neutral Safety Wire Not Grounding OEM Switch opens Starter Circuit
Brake Switch Light Green Brake Switch
Parking Lights Brown Behind Fuse Panel in Harness or Driver's Kick Panel
Head Lamp Red/Yellow (+) Light Switch
Factory Disarm Dark Green/Purple(-) Driver's Kick Panel
Door Trigger Black/Light Blue(+) On Driver's Dash below Instrument Cluster
Door Lock Pink/Yellow High Driver's Dash Negative Trigger w/Keyless Entry
Door Unlock Pink/Light Green Reverse Polarity w/o Keyless Entry
Horn Wire Dark Blue (-) Steering Column
Windows Up LF=White/Black, RF=White/Yellow
Windows Down LF=Orange/White, RF=White/Yellow, LR=Gray/Orange, RR=Yellow/Black
Old Apr 30, 2007 | 05:19 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
With a diesel the PCM is in the drivers wheel well, but I believe the white/pink is still the tach.
Old May 2, 2007 | 11:54 AM
pigfarmerdk1
Tack wire
Thanks Cookie88 & ReAX, I tried the white pink, Got 5.60 volts at idle and whent up from there with more throttle. Now I just got to get the alarm box to learn the tach signal
