1990 E150 starting problem
The problem is that it will barely turn over. Ive replaced the battery, the starter solenoid, and had the starter tested (it was fine). If i unhook the plug wires from the plugs, it turns over freely, but when i hook them up, it will baaaarely turn over. Its got the I6 engine. Can someone Please help me out??
Originally Posted by vanman13
How can i test to see if its firing in the right order?
Also make sure the ground cable from the battery is going to the block and not the frame. The cables could also be bad.
While your in there under the distributor cap, turn key and see if rotor turns. Also check to see if top dead center matches the plug location and timing mark. It could be that the gears slipped a tooth or the gears or chain are bad. When you have the cap off try turning the crank with socket wrench back and forth and have someone watch the rotor and see if there is excessive play in them. Would be easiest with plugs removed. With new battery I cannot figure out why 1 plug wire connected would stop it from turning over. Check the ground as mentioned before. You said the starter was tested, but maybe under load it is not up to par. I would have hoped that you would have had some more suggestions by now. Turn the headlights on when you crank it and see what happens. Bad ground would show itself that way.
After trying to turn it over for a little bit, the starter gets really hot, so that seems to make sense that something is wrong with starter. While trying to turn it over, could i use a multimeter to check the voltage? Would bad windings cause a change?
Stephen_E
05-09-2004 01:50 PM
patmorrison
13
02-27-2004 03:20 PM
jgdds
09-29-2002 02:27 AM
