starter stays engaged
Old Jan 27, 2011 | 08:07 PM
wizzy214's Avatar
wizzy214
82 e-100
starter stays on when running. and stayed on when key was out. had to disconnect batt. to turn it off.
what could be the problem?
i just replaced the starter selinoid 2 weeks ago.
ps. i wrecked my van and it was in a ditch on its side for 4 hrs. 1/20/11
took out plugs cranked it over for a bit.
installed plugs started right up, ran it for 30 mins last night (no white smoke)
today i got the problem above.
Old Jan 29, 2011 | 12:18 AM
wizzy214's Avatar
wizzy214
i thought the soleniod was stuck open so i got a new one.
hooked it up and its acting like i have a dead battery, with the clicking, then try again and nothing.
could my ignition switch be the problem?
Old Jan 29, 2011 | 09:31 AM
turbogus's Avatar
turbogus
Could be an issue with your starter relay, on my '81 E150 'The Oven' it's mounted on the inner fenderwell next to the battery.
Old Jan 29, 2011 | 10:23 AM
wizzy214's Avatar
wizzy214
whats the starter relay look like?
Old Jan 29, 2011 | 02:25 PM
turbogus's Avatar
turbogus
This You tube vid may help;
YouTube - Ford Starter Solenoid Troubleshooting, Replacement and Function
As the video says, if you mis wire the solenoid, the starter will continue to run as you have described. If it is unclear how it should be wired check a local parts store for information or your local library for the technical manual section (likely in reference section)
Best of luck!
Old Jan 30, 2011 | 09:46 PM
IM2HI2CU's Avatar
IM2HI2CU
Try swapping the two smaller wires at the solenoid.
Old Feb 2, 2011 | 12:48 AM
jtybt's Avatar
jtybt
There are a few things that can make a starter stay engaged. Less likely is the starter is not aligned or loose. Yours sounds electrical. There's an electro magnet that makes the starter gear push out to engage the flywheel. For one reason or another the contacts will arc and burn and sometimes weld the contacts in the engaged position. That's what yours sounds like.
Old Feb 3, 2011 | 11:59 AM
wizzy214's Avatar
wizzy214
put in a new starter solinoid, now problem is, turn key and a click sound then nothing, turn key again and nothing lights up no power.
i think a ground wire is pinched, or a power wire touching metal.
time to do some tracing.
Old Feb 3, 2011 | 12:37 PM
jtybt's Avatar
jtybt
Sounds to me like bad contacts/connections. Clean all the heavy cables at both ends on the batt and ground and to the starter.
oravecz1
1978 - 1996 Big Bronco
Aug 22, 2017 06:44 PM
Chris_stanworth
1983 - 2012 Ranger & B-Series
Jun 18, 2017 07:33 AM
Roswell
Georgia Chapter
Feb 10, 2016 08:08 AM
adamkat22
51
Sep 4, 2015 07:53 AM
m.collins
36
Apr 16, 2015 11:42 AM
