Pulley Noise
Pulley Noise
Well I spent days attempting to rule out which pulley is bad. After putting on a tension pulley, alternator, and water pump, it's now obvious that that the smog pump pulley is bad. At this point, I don't want spend anymore money. So I need a belt size that would bypass the smog pump. Do anyone know ?
Thanks
Thanks
Are you sure it's not a belt that you're hearing?
I replaced the serpentine belt on my 92 F150 w/351 because of squealing. It wasn't until after I put a new belt on it that I found out I needed to get the glazing off of the pulleys BEFORE you install the new belt....after two weeks, the squealing is back and I'm told it's too late, to eliminate the noise I have to replace this new belt...but only after cleaning the pulleys!
The measurements vary for each engine and pulley combination. I've always done the string measuring method. I've found it's best to get a couple of belts in the next smaller sizes than the string measures and try each of them until you find the one that fits best. Don't run the motor or you won't be able to return the unused belts.
MSGTG
Can you post details about de-glazing the pulleys? I just bought a new serpentine, but haven't installed it yet.
Do you de-glaze the v-groove pulleys as well? The smooth pulleys would be easy enough with emmery cloth, but how to de-glaze the v-grooves?
(maybe it's in my Haynes - haven't looked and don't have it with me)
Anyway, mine is a '95 F-150 with 351w, PS, AC, and a 102" belt OEM.
I put on a 94.5" belt (the closest I could find to what I needed). I determined the needed length by winding a flexible steel tape around the pulleys minus & bypassing the smog pump. That belt worked great until it got extremely cold, when it tended to hop off when the truck was first started. So I installed a 90mm Gates tensioner pulley (pulley only, not the whole tensioner assembly) in place of the OEM 76mm pulley. That solved it and have had no problems (either belt-wise or driveability) with this setup.
By the way, belt numbers usually tell how long they are, i.e. my original was a 102K6 (102" long, 6 rib) & I replaced it with a 945K6 (94.5" long, 6 rib). Other makes are numbered similar. They seem to come in 1/2" sizes only. For mine, a 94" was way too short, & a 95" got lost on it.
Good luck. Also, you can leave the pump on the engine if you need to re-hook it to pass emissions. The re-route will not touch the smog pump pulley.
William, deglazing is just breaking up the shine on the worn surface of the pully so the belt grips a little better.
But if you get too ambitious, it causes wear problems.
I use brake cleaner and a small brass brush. The plastic brushes don't seem to work as well.
Just an observation, DON"T use carb cleaner on a plastic pully. You can turn your plastic pully into a gummy mess if you over do it...
Dads79
05-20-2008 04:07 AM
