shorty headers on 390 Fe
Old 09-22-2015, 09:08 PM
crazy96863's Avatar
crazy96863
crazy96863 is offline
Fair enough... I am going to have heads gone through first... Would it be prudent to have them resurface the exhaust flanges? If such a thing can be done. I havent seen this ever discussed before but it seems that with all the trouble of getting exhausts to seal up it wouldnt hurt tonhave a fresh surface.
  #47
Old 09-22-2015, 09:19 PM
resonateur's Avatar
resonateur
resonateur is offline
...I would, but that's just my opinion. I really respect the knowledge that many of the FTE members bring here! Maybe someone else will chime in. Note also, the Sandersons don't use an exhaust gasket, just RTV. Also note, that the Hedmans (surface finish/coating) is not guaranteed if you have them on the engine during break-in. That tells me something, as Sanderson does not mention this.
  #48
Old 09-22-2015, 09:24 PM
crazy96863's Avatar
crazy96863
I like not fiddling with gaskets. Probably worth calling sanderson and asking to be sure. But ultimately this is a world of contracts so unless it is disclosed to not do so the issue could probably be pressed.
  #49
Old 09-22-2015, 09:30 PM
resonateur's Avatar
resonateur
....if'n you don't mind, post what you find out. I'm here to learn as much as I can!
  #50
Old 09-26-2015, 01:26 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
The FF427 header set fits 1953-Up Ford F100 pickups using the Ford 332-428 FE engines.
  • $535.00
  #51
Old 09-30-2015, 05:38 AM
SoCalRefugee's Avatar
SoCalRefugee
SoCalRefugee is offline
As I posted a week or so ago, I ordered a set of Sanderson headers. I did this after a long phone conversation with them regarding different port alignments and my concern there.
They arrived yesterday. According to the invoice they are FF427's. However, they are DIFFERENT from the ones pictured earlier in this thread.
They have 4 bolt holes per cylinder. For a stock head you would use the vertically aligned set. I believe the diagonal holes are for Cobra Jets. What I do know is that my Edelbrock aluminum heads have ALL 4 holes. In addition, Sanderson includes header bolts for ALL the holes.
I also think I know why alignment to the exhaust port is not an issue, but will have to verify it when I pull the old headers. I believe their tube hole is big enough to encompass either the upper or lower aligned ports.
I'll post more when I know.
~SCR
Note the 4 bolt holes per cylinder.
  #52
Old 10-01-2015, 09:12 AM
1972RedNeck's Avatar
1972RedNeck
1972RedNeck is offline
Wow, you should have even less of a chance of leaks with 16 bolts.
  #53
Old 10-01-2015, 10:04 PM
veetwelve's Avatar
veetwelve
veetwelve is offline
According to the Sanderson website, the FF427 headers come in two configurations... "Standard Heads" and "Cobra Jet (CJ) Heads," as well as in three different finishes.
Jay
https://www.sandersonheaders.com/san...ategory_id=630
  #54
Old 10-02-2015, 05:28 AM
SoCalRefugee
veetwelve,
I see the option on their page. I called direct and wasn't aware of this option within the same model number.
That said, everything I have read about Edelbrock heads on a 390 is that the exhaust ports match a CJ head. It makes sense.
SBR
  #55
Old 10-02-2015, 09:31 AM
TeachNlive4ever's Avatar
TeachNlive4ever
TeachNlive4ever is offline
absolutly have them surfaced!!! The ears cup, PIA to seal.
Open headers are illegal, better haul aZZ to the muffler shop. Get there as quick as you can. After you get there, you find yourself asking if they can install dump flanges.
  #56
Old 10-05-2015, 10:40 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
Sanderson's headers don't use a gasket. All that is used is a very light and thin smear of high-temp RTV to take up any irregular surfaces on your cylinder heads. That's it.
If any of you are in NorCal, Sanderson usually has a booth at the GoodGuys shows in Pleasanton. If you buy from the booth, they'll knock off like $75 from the standard price... yes, $75! I picked up another set of ceramic coated FF427s for an engine I don't have for a vehicle I have not yet built... but there is only one direction prices go and that is "up".
Btw, Hedman just came out with Sanderson FF427 clones. The price point is lower than Sanderson but I'm guessing it's due to flange & tube thickness.
  #57
Old 10-06-2015, 01:41 AM
customsport's Avatar
customsport
customsport is offline
I looked at the ceramic coated but at $550 not gonna and the painted from them was $450. I went plain at $350 and will use the tech line nano ceramic paint I used on a set I used on another conversion and have over 800 miles on and they still look good. I restored a 74 bronco for my friend and used the same paint and his look good. eastwood sells it.
  #58
Old 10-21-2015, 01:19 PM
deckertd's Avatar
deckertd
deckertd is offline
Originally Posted by SoCalRefugee
veetwelve,
SBR
So I take it the CJ FF427's fit the #60065 Edelbrock CJ Heads & line up OK? yes/no
Dan
  #59
Old 08-12-2016, 07:48 PM
wooddyusa's Avatar
wooddyusa
wooddyusa is offline
I'll let you guys know how it goes. I bought a set and plan to try and install them in the next month or so.
Sorry guys...wrong thread. How do I delete this?? Thats what I get for trying to be on the forums on my phone.
Falconater
Engine Swaps
01-06-2018 08:09 PM
maxedout94
1999 to 2016 Super Duty
15
08-22-2017 08:53 PM
XLTRat
52
11-30-2016 10:12 PM
forango
03-30-2016 10:47 AM
mos68x
02-14-2016 11:19 PM
Quick Reply: shorty headers on 390 Fe
