Anyone changed front axle lube latey?
I've got an 89 with the Dana 44 up front, I believe. Without any drain plug it looks like you have to unbolt the whole diff housing. Bolting everything back together looks real fun - like trying to keep the gasket in place, etc. I've even been thinking about drilling a drain hole in the bottom and tapping a hole for a pipe plug.
I recently bought this clean, nice running 89 with 5 liter engine. It's got 140K miles and runs great - just got back from Baja's outback and changed all the other fluids, AOT tranny, transfer case, rear axle - but the front looks like a real project! Maybe I'll just let it go, as this Bronco is so clean, the previous owners probably didn't run it much in the dirt...any comments?
[updated:LAST EDITED ON 15-Feb-02 AT 10:01 PM (EST)]Great idea, Bob...I'll check around for a clear flex hose that I can 'worm' around in there.
I have recently seen ad's for liquid 'sucking'devices - they use a one or two gallon plastic jug and have pumps attached to create a vacumn and allow you to drain anything the hose will fit into...
JHG88F350
10-06-2014 12:35 AM
bigbeise
10-12-2006 11:10 AM
notchstang92
02-04-2004 05:18 PM
