Emission warning light on and NO power
I was pulling my camper with my 2005 f150 5.4, I went to pass a slower car all was going well till the emissions warning light came on and the truck felt like it loss all power. I limped it home and tried checking it for code with my hand held but no codes were found. It is running fine no bad sounds or anything noticeablely wrong, just the light on and no power. Anyone have any ideas? Oh, it is lifted 6" and has 35" tires with cat back exhaust with 40K on it. Thanks
Bad temp sensor telling the PCM that it is over heating will put it in limp mode, and deactivate cylinders. It's a built in protection Ford has in their vehicles. I agree a bad O2 sensor will post a CEL (check engine light) along with a code and proabably run rich. The mode is known a Failure Mode Effects Management (FMEM). The PCM substitutes a working value if a sensor fails
It could have also been a miss fire, which will cause the CEL to activate.
sounds like you overheated or your temp sensor failed. the motor went failsafe. you probably did overheat a little bit.
is the truck running fine now? if the problem is persistent, then that makes me think your temp sensor has failed. that, or the PCM needs to be reset after a limp mode is actuated.
I had a friend with a BETTER scan tool check for codes and it came up with 3 codes.
1. 02 sensor bank 1 lean
2. fuel pressure regulator sensor low pressure
3. random misfire cylinder 1
I think the engine was starving for fuel since that would explain all 3 codes above. So, maybe a clog fuel filter??? I going to change it out in the morning.
bigfordandjeep
15
04-06-2009 09:18 PM
fishmanndotcom
06-05-2003 12:32 AM
