Sponsored by: Auxito
Svc Engine light at 75,069 miles???
Old Jan 15, 2005 | 08:21 PM
tealboy1's Avatar
tealboy1
My 1998 5.4 liter is running perfectly, but for unknown reasons, the svc engine light went off at just a tad over 75,000 miles. Is this an emissions related warning or is it likely i have a problem? I know i need to get the code tested and may try autozone, but was curious if you were aware of a svc bulletin at 75,000 miles
thx
Old Jan 15, 2005 | 08:34 PM
triton_2002's Avatar
triton_2002
I doubt that it has anything to to with your specific milage. In fact that's kinda low milage for a 98. Just get the code pulled at autozone, post the code # here and someone will help you out.
Old Jan 16, 2005 | 05:39 AM
tealboy1's Avatar
tealboy1
ok, thx. I was just wondering if it was emissions related and tied to mileage, at least that is what i was hoping. I will get the code today and put it on the board.
Old Jan 16, 2005 | 02:52 PM
tealboy1's Avatar
tealboy1
I got the code, it is a P0153, oxygen sensor. Is there more than one? Are they easy to replace? Is it necessary to replace? Expensive?
thank you.
Old Jan 16, 2005 | 03:02 PM
fordguy21's Avatar
fordguy21
Check out this website that describes the code
http://www.obd-codes.com/trouble_cod...2-sensor-1.php
Old Jan 16, 2005 | 05:27 PM
MBDiagMan's Avatar
MBDiagMan
This is one of the more common codes to be seen, not this exact one, because there are a few different "slow response" codes depending upon the position of the sensor.
You can clear the code and you might not see the same code again for a year or two, then you might see it a few times a week or two apart and then it might go again for a year or two.
I would suggest that you get an inexpensive scanner and then clear the code. If it comes back again, do not clear it again until you verify that it is the same code.
Odds are that you can clear the code and it will not reoccur for a long time, but anything can happen.
Good luck,
Doc
ASE Master
Robv27
Modular V10 (6.8l)
48
Nov 5, 2017 08:26 PM
Robv27
Aug 24, 2015 09:05 AM
99Exp
20
Jun 23, 2015 11:52 AM
Sal1707
2009 - 2014 F150
15
Feb 19, 2014 08:08 AM
scottb1014
2004 - 2008 F150
Jul 6, 2004 06:45 PM
