Offroad & 4x4
dodge rims will fit my ford?
Old 03-24-2007, 04:02 PM
fordinmudd's Avatar
fordinmudd
fordinmudd is offline
I can get a good deal on some real nice rock crawling rims but there off a 99 dodge 2500.would those fit my 96 f 250?im not sure.
Old 03-24-2007, 09:23 PM
cdrmotorsports's Avatar
cdrmotorsports
cdrmotorsports is offline
I'm not 100% sure, but if I had to guess I would say they won't fit your truck. I've been wrong before!
Old 03-24-2007, 10:12 PM
ReAX's Avatar
ReAX
ReAX is offline
No the 99 dodge should have a metric pattern, and I think your truck is an inch pattern.
Old 03-24-2007, 11:11 PM
fishmanndotcom's Avatar
fishmanndotcom
fishmanndotcom is offline
they WILL fit
for future reference...
DODGE
YEAR MODEL BOLT PATTERN LUG NUT SIZE
87-90 DAKOTA 2-4WD 5 on 4.5 in. 1/2
91-04 DAKOTA 2-4WD 6 on 4.5 in. 1/2
98-03 DURANGO 2-4WD 6 on 4.5 in. 1/2
74-84 RAM 1500 2WD 5 on 4.5 in. 1/2
85-01 RAM 1500 2WD 5 on 5.5 in. 1/2
74-80 RAM 4WD W/O HUBS 5 on 4.5 in. 1/2
80-93 RAM 4WD W/HUBS 5 on 5.5 in. 1/2
94-01 RAM 1500 4WD 5 on 5.5 in. 1/2
02-04 RAM 1500 (NEW BODY) 2/4WD 5 on 5.5 in. 9/16
46-81 3/4-1 TON 2WD 8 on 6.5 in. 1/2
82-93 3/4-1 TON 4WD 8 on 6.5 in. 1/2
94-04 RAM 2500-3500 2/4WD 8 on 6.5 in. 9/16
FORD
03-04 EXPEDITION 2-4WD 6 on 135 mm 14X2.00
03-04 NAVIGATOR 2-4WD 6 on 135 mm 14X2.00
00-02 EXPEDITION 2-4WD 5 on 135 mm 14X2.00
00-02 NAVI / BLKWD 2-4WD 5 on 135 mm 14X2.00
97-99 EXPEDITION 2-4WD 5 on 135 mm 12X1.75
97-99 NAVIGATOR 2-4WD 5 on 135 mm 12X1.75
83-97 RANGER / BRONCO II 4WD 5 on 4.5 in. 1/2
98-04 RANGER 4WD 5 on 4.5 in. 1/2
01-04 SPORT TRAC 2/4WD 5 on 4.5 in. 1/2
83-04 RANGER / BRONCO II / EXPLORER 2WD 5 on 4.5 in. 1/2
90-94 EXPLORER 4WD 5 on 4.5 in. 1/2
95-04 EXPLORER 4WD 5 on 4.5 in. 1/2
49-96 ALL 1/2 PICKUP 4WD 5 on 5.5 in. 1/2
49-96 ALL 1/2 PICKUP 2WD 5 on 5.5 in. 1/2
66-96 FULL SIZE BRONCO 5 on 5.5 in. 1/2
97-99 F-150 PICKUP 2-4WD 5 on 135 mm 12X1.75
00-04 F-150 PICKUP (HERITAGE) 2-4WD 5 on 135 mm 14X2.00
2004 F-150 PICKUP (NEW BODY) 2-4WD 6 on 135 mm 14X2.00
97-99 F-250 LT DUTY 2-4WD 7 on 150 mm 12X1.75
55-79 F-250 / F-350 4WD 8 on 6.5 in. 9/16 OR 1/2"
55-79 F-250 / F-350 2WD 8 on 6.5 in. 9/16 OR 1/2"
80-98 F-250 / F-350 (OLD BODY) 4WD 8 on 6.5 in. 9/16
80-98 F-250 / F-350 (OLD BODY) 2WD 8 on 6.5 in. 9/16
03-04 F-250 / F-350 / EXCURSION 4WD 8 on 170 mm 14X1.50
03-04 F-250 / F-350 / EXCURSION 2WD 8 on 170 mm 14X1.50
99-02 F-250 / F-350 / EXCURSION 4WD 8 on 170 mm 14X2.00
99-02 F-250 / F-350 / EXCURSION 2WD 8 on 170 mm 14X2.00
-cutts-
Old 03-25-2007, 01:15 PM
MBBFord's Avatar
MBBFord
MBBFord is offline
Like fishy said, they will fit, b/c both have 8x6.5" Bolt Pattern. Even older model chevy 3/4 and 1 tons have the same BP
Just like the older model dodges, 73-96 Ford 1/2 tons, Jeep CJs, and I want to say one more all have the same bolt pattern of 5x5.5
Old 03-25-2007, 11:19 PM
unrulee's Avatar
unrulee
unrulee is offline
I see that the bolt pattern is correct, but doesn't Dodge run very little back spacing?
Old 03-26-2007, 08:44 PM
brokebronco's Avatar
brokebronco
brokebronco is offline
Don't forget the center hole. It varies between manufacturers and Ford likes the big center hole.
Old 04-01-2011, 03:38 PM
mowpar's Avatar
mowpar
mowpar is offline
fishman chart
the chart you posted does not specify, what inch tires are involved, I would like to find a rim for my 93 f150,, that is bigger than 15 inches with the 5x5.5 bolt pattern 18 inches would be a nice size
Old 04-01-2011, 05:04 PM
kjett's Avatar
kjett
kjett is offline
Considering his chart is 4 years old, I'm sure things have changed/been confirmed by now. But thanks for taying on top of it Captain O.
Old 04-01-2011, 05:07 PM
300/6 Freak's Avatar
300/6 Freak
300/6 Freak is offline
yes the dodge rims wil fit. dodge and chevy and ford all have 8x6.5 untill 1999 when ford only switched to 8x170mm. The hub hole is just fine as Chevy rims (IE H2 rims) have a smaller hub hole and need to be bored out.
Old 04-01-2011, 10:54 PM
fatdan460's Avatar
fatdan460
fatdan460 is offline
i was gonna flame you, but lost interest.
Number4
05-15-2017 12:39 AM
Brody Olson
01-05-2014 11:01 PM
2006powerstroke90
04-17-2011 09:34 PM
davidson915
09-23-2010 06:07 PM
hatchet
Offroad & 4x4
09-07-2007 10:46 PM
Quick Reply: dodge rims will fit my ford?
