Supercharger
Old 03-16-2007, 01:14 PM
TheTowingCowboy's Avatar
TheTowingCowboy
TheTowingCowboy is offline
Supercharger
I've been thinking about putting a Vortec Supercharger from Summit Racing
HERE : http://store.summitracing.com/partdetail.asp?autofilter=1&part=VOR%2D4FE218%2D07 0SQ&N=700+4294908331+4294908312+4294924755+4294840 126+4294925239+115&autoview=sku
How will it effect my MPG??? Plus would I need to redo my ECU or anything, I want just a Bolt-On kit that I can use without alot of work.
THANKS IN ADVANCE. JP
Old 03-16-2007, 02:07 PM
rubydist's Avatar
rubydist
rubydist is offline
Yes, you will need to re-tune the ECU. I'm not sure if that kit includes a tune or not. Most likely it will affect your mileage, because you'll have an increasing tendency to get in a hurry! If properly tuned, and if you stay out of boost almost all of the time, your mileage should not change much.
Old 03-16-2007, 04:44 PM
Blurry94's Avatar
Blurry94
Blurry94 is offline
That kit does not come with any aftermarket tuning. However, you can get by with the supplied FMU and hook up an ignition/boost retard controller. If you're running speed density, aftermarket tuning is going to be scarce so the FMU and boost controller may be you're best bet. I would also recommend running a plug that is one heat range colder than stock to help keep the combustion temps from increasing too much...and always run the highest octane fuel available in your area.
Old 03-18-2007, 06:35 PM
TheTowingCowboy
Well then I am proably not going to run it, cause it sounds like a lot of work, and I can't waste 50 buck of gas for the hell of it (Gas at the moment in my rural area is 2.55 a gallon.)
Thanks Guys,
JP
Old 03-20-2007, 07:45 PM
DirtyDogOfTheDesert's Avatar
DirtyDogOfTheDesert
DirtyDogOfTheDesert is offline
When I first put the Procharger kit on my '05 Mustang at 8psi boost my fuel milage actually got 10% better, ...... on a longer trip when I could keep my foor out of it. But it sure liked it when I was just "running around"
Running any S/C system without a good custom tune and being sure your fuel trims and A/F ratio is accurate, is extremely foolish, and only invites a broken motor. If installed and tuned correctly you could have years, and many miles of trouble free enjoyment out of it.
Depending on what you want out of your truck, a Certrifugal type S/C may not be the best choice. They tend to make more power in the upper RPM range. A conservative amount of boost (6-8psi or so) will not give you great gains below 3500-4000 rpm.
biltfordtough
01-20-2008 09:29 PM
Twitchee2
18
01-13-2008 12:38 AM
TheTowingCowboy
19
10-23-2007 08:29 PM
FordF350Baby
06-13-2007 11:38 AM
sl001
05-04-2006 02:47 PM
Quick Reply: Supercharger
