Aerostar Ford Aerostar
97 Windstar fuel pump inertia switch?
Old 02-19-2007, 09:03 PM
smackme's Avatar
smackme
smackme is offline
Unhappy 97 Windstar fuel pump inertia switch?
Help please I bought a 97 windstar that was hit in front only damage to front clip ran fine before accident now inertia reset wont restart the fuel pump? is the switch bad or should i try something else?
Old 02-19-2007, 11:26 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
is there 12v in and out of switch?
do you have 12v to fuel pump with key on?
they are a fairly complex fragile switch with a mercury switch tumbler...never had one fail....seen thousands in use on logging road racing and creek crawler competions
Old 02-21-2007, 12:45 AM
thefarelaneman's Avatar
thefarelaneman
thefarelaneman is offline
I saw one fail.It was on an 87 mercury. I think maybe its something else causing it not to start after a serious collision. Lucky if it was just the switch
Old 02-21-2007, 01:09 AM
rdz's Avatar
rdz
rdz is offline
if your fuel shut off switch is triggered the reset button should be up push it down turn key ahead listen in tank for fuel pump running if not check fuel pump relay under hood .
dazedandcofused
08-09-2021 09:25 AM
GoldCo
03-10-2017 02:53 PM
97-psd
02-26-2016 09:05 PM
dbrydon
01-05-2016 02:37 AM
FordFanatic99
Modular V10 (6.8l)
12-29-2015 09:16 PM
Quick Reply: 97 Windstar fuel pump inertia switch?
