3.8 Pushrod install question
Old 01-24-2007, 02:02 PM
spencry25's Avatar
spencry25
spencry25 is offline
I just got the heads back from the machine shop for my 3.8 OHV and I'm ready to put everything back together. I have a questions about installing the pushrods properly. I know it says to rotate the engine until each tappet is bottomed out and then tighten the pushrod. Can't I just snug them with the cam in it's current position and torque them to specs in small levels all around? I would think that would be easier and avoid any timing issues when I start it up? Am I missing anything here? After my 390FE pushrod nightmare I want to avoid any problems. Thanks for any input.
Old 01-26-2007, 07:26 PM
97REDF1504X2's Avatar
97REDF1504X2
97REDF1504X2 is offline
You cannot effect cam timing any way what so ever by turning the motor by hand to bring the cam lobe to the base to tighten down the rocker arm.
amphiduck
11-08-2013 04:01 PM
ford141
03-03-2013 12:19 PM
66flareside
03-10-2008 07:13 PM
jamies460
01-13-2007 10:43 AM
polcat
03-14-2004 12:22 PM
Quick Reply: 3.8 Pushrod install question
