does my 89 f-150 have a tilt steering collum?
01-24-2007, 10:31 AM
it looks to be tilted all of the way up right now but i can't figure out how to tilt it down is this just how they where designed?
01-24-2007, 10:34 AM
The turn signal stalk is what is used to tilt the wheel in your truck if it has a tilt wheel. Push the signal stalk forward and it should tilt the wheel back down.
Steve
01-24-2007, 10:56 AM
in 92 and up it is next to the turn signal.
not sure on 89.
01-24-2007, 11:19 AM
on
<92 is the signal stalk like mentioned, push it forward and pull down on the wheel.
01-24-2007, 11:21 AM
87 to 91 is also on the turn signal lever.
01-24-2007, 11:24 AM
well i learned something new today.
01-24-2007, 12:25 PM
awesome thanks
thanks a bunch
01-24-2007, 01:22 PM
01-24-2007, 06:17 PM
Tilt is nice but it doesn't have the cool factor that the slide-away column you probably have on that 66 T-bird does!
01-25-2007, 11:14 AM
my 64 galaxie had a slide away column as well , i ripped it out after the car went down the driveway by it self in gear becasue of the bell crank and you cant find parts for
robrieg
04-20-2017 05:05 PM
Cg willie Willie
01-18-2017 09:14 PM
Dasher400
16
08-28-2016 08:02 PM
GuitarJesus
05-12-2016 07:33 AM
snowdog79
50
06-10-2007 08:47 PM
