Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Dyno results
Old 01-21-2007, 11:22 PM
spider1472's Avatar
spider1472
spider1472 is offline
Dyno results
Ok so I am not sure how to put the scanded dyno sheet on here but the results on my 02 H.D are before the 6lbs pullie 345.61 max power 447.78 max torque after 381.65 Max power and 481.81 max torque the only other changes I know of is a cold air intake
Old 01-22-2007, 01:27 AM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Nice numbers.
Who did the tune?
Stewart
Old 01-22-2007, 10:53 AM
spider1472's Avatar
spider1472
A place in central texas called sunshine profromance
Old 01-22-2007, 12:12 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
What brand dyno was he using? Sounds like they put in some sort of correction factor because those numbers are too high for wheel horsepower (the HD is rated at 340 HP at the crank, not the wheel).
Old 01-22-2007, 08:32 PM
spider1472's Avatar
spider1472
The slip says Dynojet research on top so I am guessing that is the type that they used. Not really sure if the truck had any thing else dune to it I bought it used and not from the owner.
Old 01-23-2007, 12:41 AM
spider1472's Avatar
spider1472
[/img]well I hope that this works
Old 01-23-2007, 09:40 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Yeah, he's put in some sort of fudge factor to take into account its at the wheels. A HD F-150 (or Lightning) is not going to get 381 at the wheels with a tuner and a minor pulley change, or even with long tube headers added to the mix. It would take a lot more. He's done something to give you a chart that reads like crank HP rather than wheel HP.
Old 01-23-2007, 09:48 AM
spider1472's Avatar
spider1472
COuld very well be but I am back in afghanistan so it is hard to talk to him and find out lol I do know that about 10 mph and punch it I am breaking the tires free
Old 01-26-2007, 10:04 AM
spider1472's Avatar
spider1472
I called the people that tuned the truck he said the the machine is calibrated and the is no way that the could fudge the results. He did a coustom tune off his laptop which is where more of the HP's come from. He also said the his dyno will not read anything but rear wheel results.
Old 01-26-2007, 11:29 AM
Blurry94's Avatar
Blurry94
Blurry94 is offline
The ones I've seen with those mods are putting down 360-370hp to the wheels on a Dynojet type dynometer. The ones in the 380-400 range have headers and/or catback with those same mods....are you sure that the only aftermarket parts installed on it is a pulley and cold air intake?
Old 01-26-2007, 08:33 PM
spider1472's Avatar
spider1472
No, I bought it used and I am not sure. I have never had the chance or really know what the Diff. in some of the things are. I am mostly an older car kinda guy but I am loving the HD. I would not really beable to say if any thing has been done. but as far as I know that is it.
Huntersbo
03-05-2011 05:04 PM
senix
6.4L Power Stroke Diesel
13
05-11-2009 07:25 AM
86halfton
2004 - 2008 F150
06-08-2008 07:27 PM
kenneBF250V10
Modular V10 (6.8l)
22
08-04-2005 06:01 AM
jasfaa
10-24-2004 01:49 PM
Quick Reply: Dyno results
