Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Southern Region > North Carolina Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
North Carolina Chapter Join Chapter, Leader:ncheavymetal
  #1 (permalink)
Old 01-11-2007, 04:33 PM
dixiemudder04's Avatar
dixiemudder04 dixiemudder04 is offline
2006 Ford F-150
dixiemudder04 is starting off with a positive reputation.
add a leafs
anybody know where i can get some 3" add a leafs for my 78 f150 around here?? I want a cheap pair of used ones. I have 3" susp now and if i put those 3" aal on i'll have 6" susp correct??
__________________
2006 Ford F150 Ext cab, long bed, 4x4, 4.10 w/ limited slip, 5.4L triton, K&N CAI, Preditor Programmer, 2.5" AS leveling kit, 1 chamber mufflers with 45* 4" tips out to the side, 17x8 eagle alloy 058, 20% tint, 305/70/17 nitto a/t's
  #2 (permalink)
Old 01-11-2007, 05:38 PM
79 Trailer Special's Avatar
79 Trailer Special 79 Trailer Special is offline
2003 Ford F-150
79 Trailer Special is starting off with a positive reputation.
I have never seen an add a leaf that gives 3 inches of lift. Im not sure if you are confused or not, your 78 uses a 3" wide spring so the aal would need to be that wide. As far as lift, they usually only give you about 1 1/2 to 2 1/2 inches and 2 1/2 is not common. If your sig is correct then you have 3" body and 3" suspension now, that should be more than enough for your 35's. Am I missing something???
__________________
They call me Rick....along with a few other names I cant repeat
I'll keep my guns, my freedom and my money, you can keep your "change"
  #3 (permalink)
Old 01-12-2007, 05:46 AM
2006 Ford F-150
yea. i know i have 6" total now. i want 9" total so i can fit either 39.5's or 42's. I found this on jeffsbroncograveyard... http://broncograveyard.com/bronco/i-...long_pair.html. on there it says it'll give 3" of lift on a pickup.
__________________
  #4 (permalink)
Old 01-12-2007, 05:45 PM
2003 Ford F-150
Now it makes sense. I would call them to double check. Being you have lift springs which have more of an arch to them than stock I doubt those aal's will do the trick....not 3 inches worth anyway. I added a full length aal to a Bronco I previously owned and and it did raise it close to 3 inches on a stock spring then a buddy tried it on his truck with a 4 inch lift and it did not raise the truck at all. If you compare the arch of the speings you will see what I mean.
__________________
  #5 (permalink)
Old 01-12-2007, 06:54 PM
ncfirefighter46's Avatar
ncfirefighter46 ncfirefighter46 is offline
Garage is empty, add now
ncfirefighter46 is starting off with a positive reputation.
well i would do some checking but i would not use a suspison lift and a body lift together, it is not recommend, sec i have a 6 inch on mine and i can run 38's. but i have to ask a question do you realize with that much lift the truck would be unsafe with that short of a wheel base. and your gas milage is going to sux
  #6 (permalink)
Old 01-13-2007, 06:44 AM
2006 Ford F-150
how would it be unsafe?? my buddy had a 84 scottsdale 17" of lift with 44's. And i dont really care about the gas mileage, its just a toy.
__________________
  #7 (permalink)
Old 01-13-2007, 09:18 AM
the bronco has a short wheel base and it would be very top heavy and the center of gravity will be very high. that is what i am trying to say. i had a bronco and it would jack knive, real bad pulling a trailer. i like the broncos but i just dont want any one to hurt, you can lift if you want but becareful driving it. it will handle a lot different.
__________________
73 ford ranchero gt (rebuild stage)
Will the last american > PLEASE grab the Flag
  #8 (permalink)
Old 01-13-2007, 11:10 AM
2006 Ford F-150
alright thanks man! I was just thinking that a full size truck doesnt have a short wheel base. its a f150 long bed. so how would i get 6" in the back without putting new spring packs on it??
__________________
  #9 (permalink)
Old 01-13-2007, 11:03 PM
i miss readed my bad. i thought it was a bronco but i bought a kit for my 73 f100 long bed. same as the 79. it was a complete kit 6 inch superlift. had the blocks and add a leafs, and new coils and bushing track arm drop pit man arm. and pro comp es 1000 shocks, through 4wheelparts center. and i also got super swamper tsl. with shipping for around 1300.00. now you can still get parts there for a lift. for the older trucks but i think the only company that still make kits for them is superlift that is what mine is. they make one up to 9 inches for the trucks. maybe a 12 inch not sure.
__________________
  #10 (permalink)
Old 01-15-2007, 06:34 AM
2006 Ford F-150
for now i only want 9" total with 39.5's or 42's. so in the kit they gave ya blocks and aal's?? can u get me the sizes for them. or tell me what they are. i'm going to use the stock block cause its 3"s. But if u can get me a part number for the aal??
__________________
  #11 (permalink)
Old 01-15-2007, 01:19 PM
Quote:
got to www.4wheelparts.com they can answer all your question on a lift that is where i got mine
__________________
  #12 (permalink)
Old 01-15-2007, 01:42 PM
2006 Ford F-150
ok well after i jacked it up and let the weight off the suspension. the 6" coils i bought are the same height as the ones on there now. The rear has an add a leaf in it. so i guess im sitting with 6" susp now. but my truck is still short i think. do yall think i can clear 39.5's with out rubbing?
__________________
  #13 (permalink)
Old 01-15-2007, 06:04 PM
2003 Ford F-150
Im running an all spring 6" lift and clear 37's no problem. IIRC you also had a 3" body lift so with all that together you should be looking at 9" or so of lift. I think that will clear 39.5's as long as your measurements are correct and the springs are not soft. Also double check the actual height of the tire while it is mounted. I have seen many which claim to be a specific size but in reality they ran a bit short.....I have seen a 1 1/2 inch difference so its worth checking.
__________________
  #14 (permalink)
Old 01-17-2007, 06:30 PM
2006 Ford F-150
ok... i lied....i think i have 4" coils. the ones i bought were 19-1/8" long. I'm looking at some 6"(really 6" this time) and seeing how i have an add a leaf in there already, i'm going to get a 1" steel block and put under my 3" block so that will make 6" correct? A 1" block is what the 6" kit give you right??
__________________
  #15 (permalink)
Old 01-17-2007, 06:35 PM
MAKO314's Avatar
MAKO314 MAKO314 is offline
MAKO314 has a good reputation on FTE.MAKO314 has a good reputation on FTE.
dude I'm new to lift and such but I don't think I would stack blocks that could be dangerous
__________________
Ashley
2000 F250 Destroked "Frankinstien" CR 5.9 Cummins 631 HP 1389 lbtq
2003 explorer limited AWD V8
1990 7-UP mustang 5.0
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
