Excursion rear hatch lock actuator
After having read the tech folder sticky at the top of the page, I am just looking to be sure that I am going to buy the correct actuator for the rear hatch of the Excursion. The sticky states in one place about rebuilding the actuator that it is the right side actuator, however at the bottom it lists the part number with the left side actuators.
Can someone please straighten me out on this and then correct the sticky for others. Thanks.
I would just look at my others on the doors, but for now only the rear is broken. Incidently I tried the rebuild but on assembly I cracked my casing.
Thanks a lot.
Tim
Thanks a lot.
Tim
I just took my actuator off of the rear hatch. The arm that is attached to actuator is snapped and im sure it is because the pin it is supposed to move is jammed. My key turns no prob but the latch wont budge. If i can get that loosened a new actuator should do the trick. The reason i opened it up at all was because the door ajar sensor doesnt work. Does the actuator control this as well or do i need toblook elsewhere to solve that issue? Thanks
Unfortunately, they don't seem to cover sliding the actuator off of the bracket. One of the articles says to "pull it towards you".
In my case I broke the tabs that hold it onto the bracket trying to get it off.
Another thing is that the aftermarket replacements will not slide onto the bracket while it's mounted due to clearance, you must unmount the bracket, then unmount the wiper motor to be able to slide it out (to the left), mount the new actuator and reverse the process to reinstall it.
I never had a problem with mine though, so the memory of the time I removed the actuator doesn't stick out, sorry.
Stewart
On the actuator, between the two curved slots for mounting, there is a slightly angled peice of plastic, nylon, whatever material the actuator case is made of. This works as a locking mechanism and holds the actuator in place. To remove it (rear hatch) you need to insert a screwdriver from the top (there is a small port) and apply pressure to that locking mechanisme to disable it. Once pressure is applied you can pull the actuator away from the lock mechanism.
On my hatch there was not enough room to wiggle the actuator off it's mount you release the latch. There's just not enough clearance without the whole bracket moved out of the vehicle.
Whats good is that I got to clean the whole mechanism and re-lube it before I put it in, works like a charm now.
1997 Expedition EB
1997-2006 Expedition & Navigator
10-28-2010 06:20 PM
