Rear hatch lock
Old Feb 3, 2011 | 10:48 PM
saints's Avatar
saints
Rear hatch lock
My rear hatch won't lock and I torn into lubing or replacing the actuator. After looking things over, my hatch key lock looks bad. It won't turn with the key and look corroded. Does anyone know how to replace the lock?
Thanks
Old Feb 3, 2011 | 10:55 PM
wpnaes's Avatar
wpnaes
Good reading here, let us know if this helps.
https://www.ford-trucks.com/forums/1...wont-lock.html
Old Feb 4, 2011 | 07:33 AM
saints's Avatar
saints
Ya I used that post to tear into it. Lubed it all up but my key still won't turn the lock even with the rod unhooked. Didn't know how hard it would be to replace the lock.
Thanks
Old Feb 4, 2011 | 04:25 PM
wpnaes's Avatar
wpnaes
As i recall the lock - part # 434342 - is held in with a c-clip. Can be pulled from the inside with needle nose pliers. Take it to a locksmith who can fix it (clean?) or get you a replacement.
Old Feb 4, 2011 | 07:59 PM
CrzHelm's Avatar
CrzHelm
my hatch dont work with the key either. I thought maybe the po changed the lock. now i'm curious.
Old Feb 14, 2011 | 11:28 AM
3fingervic's Avatar
3fingervic
My hatch will unlock with the key pad and the unlock button in the X, but it will not lock. I can lock it with the key, however. Is this a lock actuator issue?
Old Feb 14, 2011 | 03:43 PM
wpnaes's Avatar
wpnaes
If you have some time, open up the plastic panel and work the linkage by hand a few times. Add some lube on the linkages and see if that free's up the movement. A lot of dust gets in there and may be binding the works. See link above to the unlocking mechanism diagram.
andym
Apr 13, 2015 07:36 AM
EXv10
Nov 8, 2013 10:30 AM
3cv
Jan 2, 2013 11:47 AM
1997 Expedition EB
Oct 28, 2010 06:20 PM
Skip1970
Mar 16, 2010 02:04 PM
