51 Ford F6 Emergency Brake.
The emergency brake was worn down to where the only thing left but the rivets. Is there a place to get the new lining or do they sell the whole round portion together? Also since it was worn into the rivets can you turn the watcha macal it or the drum portion on the back of the tranny?
You should be able to get that relined. A good autoparts store or truck shop should be able to set you up. How deep are the scrapes in the watcha macal it? (love the techincal term) If they aren't really deep I wouldn't even worry about it. It's been my experience that these brakes are better for "parking" than "emergencies".
I ditched mine when I wen twith newer engine and gearbox. Then built my own as a disc brake parking brake. Many aftermarkets do mechanical disc brakes. I used the rear disc brake caliper off a Taurus and a brake disc from an MGB. Build a bracket, modify the disc, adapt handle to caliper and after a 85 quick hours I am finished.
aussiecowboy
12-28-2023 05:36 PM
PStruwing
02-05-2015 05:44 AM
Christopher2
01-02-2005 10:04 PM
