'56 F600
Absolutely,
I am putting a 1960 292 in my 55. All the Y-blocks will bolt right up.
And no, you have to stay with a Y-block but there's nothing wrong with a Y-block!
I had my 29 rebuilt to include balancing, porting and an aftermarket cam.
It's also going to have slightly higher comp ratio. I expect it to run pretty nice.
Regards,
Rick
Regards,
Rick
Originally Posted by Fat&Bald
Found a '56 F600 flatbed locally with what the owner thinks is a very tired 272, I could pick this truck up fairly cheap. Is there a later model engine that will bolt up directly to the stock trans or is it necessary to stay within the Y-block family?
i have bought a few F500/600 trucks that have had both 302 and 351 clevelands fitted in place of the Y block, i like the look of a Y block, but clevelands seem to be cheaper HP and more redaly available, after 3 years of trying to find a factory 4 barrell manifold for the y block i'm no better off, even though u trip over cleveland ones.
cya..gary
cya..gary
I put a 390 in my 1956 F600 after the y-block expired. I was gonna leave the original trans. However, the 390 came with a 4 speed. Putting the 390 in was pretty simple. Aftermarket crossmember engine mounts, modified trans crossmember. Lengthen the clutch rod and convert the throw out arm from a push style to a pull style. Best conversion I've ever been a part of.
Thanks for the replies so far. Took a few pics of the truck last weekend and posted them on picturetrail:
http://www.picturetrail.com/gallery/...30308&offset=0
The truck is pretty much complete except for the driver side hood hinge and the driver's door window is missing. Also has some kind of tommy-lift hydraulic set up out back.
The engine and trans are still there but the probably needs a rebuild. But since I haven't heard it run and I'm just going by what the owner says maybe it just needs rings.
My initial thought was a 360\390 swap. What's the top speed on this size truck? It would be nice if it could do about 65mph.
Received 1,354 Likes
on
[QUOTE=Fat&Bald]Thanks for the replies so far. Took a few pics of the truck last weekend and posted them on picturetrail: [url
http://www.picturetrail.com/gallery/view?&p=999&uid=3609507&gid=14352303&&imgid=215030 308&offset=0[/url]
QUOTE] Looks in great rust free shape, around here it would have a high price put on it.
rustyrelic
04-23-2008 11:46 PM
ksmith203
17
03-25-2007 01:18 PM
WALFORD'S 56
11-02-2006 10:51 AM
