Idles great, won't rev
Old 11-20-2006, 06:14 PM
GusGus's Avatar
GusGus
GusGus is offline
Hi guys. I just bought a rough 1964 F-250 with the 292. While I am no stranger to the y-block, I am also not a mechanic. The problem I am having is that the truck fires right up and idles well; a little rough, but decent. When I try to give it any gas (choke on or off, no difference) It coughs through the carb and stalls. I just got everything I need to convert to late model wide dist cap and the pertronix points replacement; basic tune up stuff. Anything else I should be looking at?
-Andrew
Old 11-24-2006, 01:01 AM
pcmenten's Avatar
pcmenten
pcmenten is offline
You might have a vacuum leak. Does the truck have power brakes?
Old 11-24-2006, 07:08 AM
312's Avatar
312
312 is offline
when your all done and its still not right look at the carb.
Old 11-24-2006, 09:31 AM
GusGus's Avatar
GusGus
GusGus is offline
Got it
Well I completed the dist cap conversion, corrected the firing order, changed the plugs and wires, and updated to the Pertronix unit. It turns out that aside from the firing order being wrong, the neg coil wire to the points was loose. After changing the plugs I did look into the carb, and the choke was stuck closed.
Now the problem is going to be figuring out what carb is on this truck.
It is not stock as it's got an automatic heat-spring style choke on it (not electric). It looks like a FoMoCo (Holley) 2 bbl, but it doesn't have any tags or stamps on it. But, that's another problem.
Anyway, the truck runs great with just a little tune up and unsticking the choke!
thanks
Andrew
**edit** No power brakes, those look to be all stock manual drums, and the plugs were rich fouled.
ap67et10
New Member Introductions
04-15-2014 08:30 AM
andysam
S. California Chapter
01-08-2014 10:26 AM
grizzlypaugh
2004 - 2008 F150
04-28-2013 07:57 AM
XDAndy
11-18-2010 11:12 AM
Andrew Ortiz
1999 to 2016 Super Duty
16
06-20-2007 11:58 AM
Quick Reply: Idles great, won't rev
