tachometer problem
Old 04-09-2014, 06:27 PM
bigham25's Avatar
bigham25
bigham25 is offline
Unhappy tachometer problem
i have a 91 ranger four cylinder manual. it didnt have a tach when i bought it so i bought a replcement used cluster with a tach. well i got it plugged up and put in but when i start the engine the tach reads about 500rpm idle and never goes past about 1000 while driving. what could be wrong with it and how do i fix it?
Old 04-09-2014, 10:27 PM
Old93junk's Avatar
Old93junk
Old93junk is offline
Did you turn the little screw on the back of the tach to the other setting, it probably came out of a v-6 truck and needs to be set to 4 cylinders.
Old 04-09-2014, 10:33 PM
bigham25's Avatar
bigham25
bigham25 is offline
So as a stock tach it will have that adjustment? Someone told me only aftermarkets have the selectors
Old 04-10-2014, 10:09 PM
Old93junk's Avatar
Old93junk
Negative, the stock tach has a small green adjustment switch on the back, you need a small flat blade screw driver to change it over from 6 to 4, it is NOT marked just move it to the other setting if it came from a 6 cyl Ranger.
I did this recently on my 93 2.3 Splash which came with no tach, took a cluster from a 94 4.0 v-6, moved the switch, installed and tach runs like a charm.
79boston150
05-06-2009 06:43 PM
Blueovals&Blacksmoke
09-16-2008 05:25 PM
Thoth88
02-11-2004 12:44 PM
loudfords
03-21-2002 05:53 PM
Quick Reply: tachometer problem
