Go Back   Ford Truck Enthusiasts Forums > Misc. > Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners Tonneau cover, caps, racks, canopies, shells, etc.SPONSORED BY:
Click Here
  #1 (permalink)
Old 11-19-2006, 08:28 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
Garage is empty, add now
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
Stacks, toolboxes, tonneau and toppers????
So what are your guys running stack and or toolboxes using for a tonneau cover? also anybody running stacks up through a topper. My new truck (pick it up in 2 weeks) has a dual 6" smokers. I want to keep them but the kids stuff and michigan snow make it difficult to use a top or tonneau for the winter. I am trying to come up with a good solution. any ideas? i was thinking it may not be too hard to modify a tonneau cover to fit the shortened area of the bed. I could also move the stack in toward the center of the truck a few inches and cut two hole in the toper to run the stacks up through but not real crazy about the idea.
I was also thinking of a quick change exhuast where i could just throw a side pipe on it when i need the topper on but thats a bunch more work. I like 15 minutes change overs not 2 hours change overs? any thoughts or experience to share?
Thanks
Truckless in Michigan (but only for 2 weeks)
__________________
Tim
1997 F-350 CC 4x4 PSD Auto 302K
AD's, IC, Rear Disc, OBA, Tuned by Tony Built by me!
Transmission by Racer X!
  #2 (permalink)
Old 11-19-2006, 08:51 PM
sneal's Avatar
sneal sneal is offline
sneal is starting off with a positive reputation.
sneal41
You might look at how a flue exits a roof, there might be some application that you could put into a topper to fit your application. Depends on the temp of the stack where the topper would make contact you might not even need the special boot for high temp applications, you might get away with a rubber boot that would slide down over the stack and form a seal. My nieghbor has a transfer tank and put a short box topper on his truck behind the tank and just built a small plywood wall to extend the topper front to the bed of the truck. He painted it to match and sealed it with Buytal caulk for flexibility, looks pretty good and he has the function of the transfer tank and dry storage. Congrats on the truck!
__________________
Scott
1997 f350 7.3 PSD, CC, LWB, E4OD, 4X4, fpr shim, 6637, 3-4 dp, stage one 160cc,dp6 pos and tunes, evp delete, no kitty and its muffle went too, IDM (140) mod, 15v Stancor and Gauges. Dominator 66 turbo from Beans!!! and live Beans tunes. Now I need a set of ladder bars and an Aumor bumper w/ air tank!!!
  #3 (permalink)
Old 11-20-2006, 06:11 AM
tjbeggs's Avatar
thanks sneal. Prior to finding this truck I was thinking about stacks and had a thought about ceramic coated stacks. Then a rubber gasket would work no problem. Keep the ideas coming!
__________________
Tim
  #4 (permalink)
Old 11-20-2006, 09:13 AM
kellie_truxedo kellie_truxedo is offline
kellie_truxedo is gaining momentum as a positive member of FTE.
Here at Shur-Co we custom build the Truxedo Lo Profile to go behind toolbox applications. I'm not sure how that would work with your stacks, but you can check out the Gallery at truxedo.com to see how well the custom covers work with toolboxes.
  #5 (permalink)
Old 11-20-2006, 11:35 AM
tjbeggs's Avatar
thanks kellie for the info. I also foudn a guy on ebay user name "intrigued" he said he could make a custom one for $220. I beleive it is hinged at the front so it is easy to remove and could flip up for bigger objects on the tail of the truck. I am getting some more info on it now but sounds pretty good to me.
any other ideas?
__________________
Tim
  #6 (permalink)
Old 11-20-2006, 01:54 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Back in my old street rod days we used to put a cutout in the exhaust that would allow us to select between straight pipes for the "occasional" drag race or the muffled (well sorta muffled) system that kept it legal.
You could apply the same principal and make the stacks easily removable (better use stainless pipe) at a point that will allow using a cover in winter.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #7 (permalink)
Old 11-20-2006, 02:00 PM
tjbeggs's Avatar
I have thought about that but the stacks still have to come off in order to fit a cover. would be just as easy to have flat band clamps ona 90 degree bend just under the bad that i could take off put the side pipe on. I don't really want my undercarriage all sooted up from just a turn down. That is good thinking though! thanks
I am think the custom tonneau is sounding pretty good. Just won't fit as much as the topper when we go camping and what not. Too bad a short bed topper aft of the toolbox and stack would look really dumb! but it would be functional!
__________________
Tim
  #8 (permalink)
Old 11-22-2006, 10:53 PM
westtntrucker's Avatar
westtntrucker westtntrucker is offline
westtntrucker has a very good reputation on FTE.westtntrucker has a very good reputation on FTE.westtntrucker has a very good reputation on FTE.
I am going to assume your new truck will be a long bed. Get a tonnue for a short bed and the space from the front of the cover to the front of the bed can be made with some sheet metal and small angle iron with hole flame cut to let the stacks thru. for water proofing, High temp RTV should do the trick.
  #9 (permalink)
Old 11-23-2006, 09:19 AM
tjbeggs's Avatar
Thanks that might just work too. I will be picking the truck up in a week so then I will know the spacing. A short bed cover would be the easiest!
__________________
Tim
Tags
bed, boxes, built, cover, custom, ford, put, short, stack, stacks, tono, tool, toolboxes, topper, toppers, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
