My Bronco
Specs
Here is a copy paste from my web page. I just stuck a car tranny in it for now. But I could put the original tranny with transfer case back in but it would last 5 minutes with this engine.
Pat
<TABLE cellSpacing=1 cellPadding=2 width="100%" border=0><TBODY><TR><TD class=padded>950+ HP Siamese bore 4 bolt main A-460 Big Block Ford 598 C.I. 4.600 Bore X 4.500 Stroke Bryant 4340 forged crank, 6.8 Crower 4340 steel billet rods ARP main studs, Fully race prepared Super Cobra Jet heads by Jon Kaase Racing http://www.jonkaaseracingengines.com/ Comp Cams Custom cam grind by Jon Kaase, Mechanical Roller .761lift Dur. 280/300 @.050, Crower Hippo lifters roller rockers Manley Nex Tech Valve springs Custom Forged JE Gas ported pistons 14.9 compression, Ported Victor Jr. intake, Pro Systems 1250 Holly Dominator with dual regulators and Barry Grant 400 GPH fuel pump, MSD Digital 7 programmable # 75301, MSD #8261 coil, MSD Pro billet distributor,
Custom 3 step headers , Moroso Pro Eliminator oil pan, Moroso Electric water pump, light weight aluminum radiator , Auto Meter Dual Channel (engine and drive shaft) recording tach</TD></TR><TR><TD class="bodyBold background1 padded" vAlign=top>Drivetrain:</TD><TD class=padded>Hughes Performance C-6 with wide ratio gear kit 2.72 first 1.54 second, Hipster transbrake, 9 inch 5200 stall converter, Chrome Moly 4 linked Ford 9 inch with Strange Pro Iron case Strange 4.71 35 spline Pro gears Mark Williams 40 Spline axels and spool, Weld Draglite Wheels and Hoosier 32.5X 14.00 slicks</TD></TR><TR><TD class="bodyBold background1 padded" vAlign=top>Notes:</TD><TD class=padded>First time out with 598 Motor ET 10.70 and 123 MPH </TD></TR></TBODY></TABLE>
Pat
justshootme84
01-22-2010 08:25 PM
