1978 - 1996 Big Bronco
tailgate window problems
Old Nov 22, 2006 | 10:15 AM
gimmeice3's Avatar
gimmeice3
Arrow tailgate window problems
so my tailgate in my 87 bronco won t roll up it is stuck in the down position, and i would believe it is the motor, which i cant access because the glass is in the way, does anyone have any suggestions for how to fix this to access the motor i appreciate all the feedback i can get thanks - matt
Old Nov 22, 2006 | 11:42 AM
cje07's Avatar
cje07
Here...
Did the motor all of a sudden stop working?
Could be that the latches are not fully engauged. If the window switches work, the latch must be fully closed to defeat the safety interlock switch. Trying closing the tailgate again and make sure to push the latch handle all the way down before operating the switch...have you ever heard of someone putting shoulder pressure on a corner of the tailgate and a buddy pushing the button? Sometimes the rod inside the tailgate gets bent and messes the safety interlock switch.
If the window can't be moved by the switches, find the motor connector apply 12V power to the 2 exposed wires to operate the motor. This can be done using a battery charger. Just reverse polarity...this can be done even if your tailgate is open since it bypassess the safety switch/rod.
This link should help you out. It is a link to Steve83's site in regard to tailgate tech...plenty of pictures and plenty of explanations...oh and diagrams.
http://www.supermotors.net/clubs/sup...try/2742/12689
You might want to get a superford account too (if you do not already)...its free and you can host pictures for uploading.
Another common motor problem:
The picture below is compliments of Steve83. You will notice the green arrow...these are the torque pins and will get worn out after many years. This is the reason many windows do not work, they get oblong, pinch and prevent the motor from raising/lowering the window. The replacement kit (which includes the torque pins) is around $15.
