1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
I'm trying to replace my license plate lights
Old 11-12-2006, 05:13 PM
1991lariatxlt's Avatar
1991lariatxlt
1991lariatxlt is offline
My license plate and running board lights don't work any longer. I'm not sure why exatly but I need to replace the license plate lights. I checked my manual but there doesn't seem to be any mention of these lights anywhere.
~Thanks for any help I was informed of this problem by the highway patrol
Old 11-12-2006, 05:56 PM
ReAX's Avatar
ReAX
ReAX is offline
The bulb is a 194 according to my lookup.
Old 11-13-2006, 12:35 AM
RACERX7775's Avatar
RACERX7775
RACERX7775 is offline
you may be able to get a tiny arm behind there and get the bulbs out. other than that, i broke mine trying to get them out from the front. $16 for the pair..
Old 11-13-2006, 05:51 PM
ryaneverk2's Avatar
ryaneverk2
ryaneverk2 is offline
They're tricky little buggers. The little grey housing part actually stays stuck into the bumper... don't pry on it or anything. Reach in from behind (easiest if you lay under the truck) and grasp the light by its socket, and give it a little twist (quarter turn or so). Can't remember which direction. It'll come right out, then, socket and bulb. Replace the bulb, reinsert into the housing, give it a twist back to lock it in.
cchsbuzz19
Electrical Systems/Wiring
01-19-2015 04:18 PM
KodiakF250
03-07-2012 12:34 AM
weyland426
04-18-2011 06:27 AM
thefnswits
10-14-2008 07:37 AM
DLT
07-29-2003 08:06 AM
Quick Reply: I'm trying to replace my license plate lights
