sealent between the front lower cowl panels?
well im about ready to replace the front corners of my cowl in the process of stripping the paint off to find the spot welds i also exposed the seams of what appears to be some kind of sealent between the upper cowl and the fire wall and the lower cowl pieces does any body have a suggestion on this area i plan on mig welding the new panel in place by using rosette welds in the area that i cut the spotwelds loose from. i would be grateful for any info
thanks
gee ooh
thanks
gee ooh
gee oh,
I went to my local automotive paint supply store and bought a product called "seam sealer." I think it was made by PPG, but I'm sure there are several out there to choose from. It comes in a cartridge that fits in your caulking gun, so application is easy after all the welding is complete. About $7-8 per tube a few years back and one tube did the entire cab. I also used it in the rain gutters, after I removed the old, cracked stuff (you can shape it with your finger before it cures, just like caulking). It is paintable and cures firm, yet some-what flexible.
A high grade paintable silicone caulk from your local home improvement store might work just as well, but I haven't tried it myself.
Good luck,
Kent
56 F-100
Good luck,
Kent
56 F-100
Don Vito
11-05-2020 11:00 PM
ulev1st
49
04-16-2016 09:27 AM
salvaged66
07-02-2012 10:35 PM
crazyeddie
11-18-2010 09:39 PM
mekellymoore
09-13-2005 10:52 PM
