Replacement Cowl Vent Panel?
Old Nov 3, 2010 | 05:54 PM
crazyeddie's Avatar
crazyeddie
Does anyone know if there are replacement cowl panels available for 73-79 pickups?
The floor under my cowl vent panel is split straight down the middle from the driver's side all the way to the passenger side. It looks like water didn't drain too well and it corroded the steel just enough to make it split in the middle.
I need to get the vent panel off to weld a patch in the floor. If I cut the spot-welds and chisel the panel off, it's as good as destroyed.
Any suggestions? Thanks guys!
Old Nov 3, 2010 | 06:23 PM
650's Avatar
650
I don`t think there is a repro of the cowl pannel for these trucks.
Old Nov 5, 2010 | 04:18 AM
Friesian-Bronco's Avatar
Friesian-Bronco
Not that I know of either...
Sounds like an awful lot of work, especially with a non replaceable panel, might be time to look for another good cab... Or maybe another cab thats reeeeaaaly gone, and destroy the rest of it to get the cowl off intact to replace yours..
Hmm. Better thought;
Can you pull the cab and do the floor repair from underneath?
G.
Old Nov 6, 2010 | 01:39 PM
Hyperactive460's Avatar
Hyperactive460
i have a 78 cab that i'm getting ready to scrap, might be able to cut a section out for you.
Old Nov 10, 2010 | 07:04 PM
crazyeddie's Avatar
crazyeddie
Thanks for all the replies gentlemen!
Cab swap is a little more work than I'm willing to get into although dicing up a cab at the junkyard with a sawzall could work. I'm yanking the motor this winter so I might be able to get at the cowl-floor panel from underneath, just not sure how I'd hide the patch job on the top-side. I was thinking about dumping some self-leveling sealer in the cowl and just covering the work that was done, but not sure if it'd work or not. I was also debating shaving the cowl vents - looks cleaner and hides the crack in the panel.
Thanks for the offer Hyperactive460 but there's plenty of 73-79's in my local junkyard to dice up. I appreciate it though!
Old Nov 10, 2010 | 10:06 PM
650's Avatar
650
I think you can just pull the dash out and weld the water drain floor`s hole shut from behind instead of ripping the cowl off and going in from above.
Old Nov 10, 2010 | 11:45 PM
decoy's Avatar
decoy
Question 79 ford f-150
I use my 79 ford to plow snow. As I'm plowing the wipers will quit working for awhile then take off again. Not a good deal when there is snow coming down.
Was told I might need a bigger alternator. Okay got the biggest I could get at Napa. Didn't stop the problem.
What might be going on and how do you get to the wiper motor to replace
Thanks
Old Nov 10, 2010 | 11:48 PM
650's Avatar
650
Do you have the intermittent wipers? Also the wiper motor is gonna be a pita to get off and replace.
Old Nov 11, 2010 | 12:12 AM
decoy's Avatar
decoy
No, just the two speed..............pita huh? Yikes
Old Nov 18, 2010 | 09:39 PM
crazyeddie's Avatar
crazyeddie
Good idea, although I don't think there's enough room to get a cutoff wheel in there to cut out the bad patches or even weld in new material going in with the dash out. The crack in the floor runs almost the whole length of the panel. Just painted my interior too
Think I'm going to cut the cowl vents out, fix the floor while it's open, then fill/shave the vents. If I fill them, the patch job doesn't have to be pretty
Thanks for the ideas everyone!
abe
Jul 2, 2021 12:21 PM
FuzzFace2
Jun 25, 2016 08:52 PM
Steve Clarke
Apr 29, 2016 03:36 PM
Outlaw56
Dec 14, 2015 01:25 PM
beartracks
Dec 23, 2014 01:56 PM
