2001 supercrew diff chattering
I have a 2001 Ford SuperCrew 5.4L, and the 9.75 LS rear axle... i had a bering go out about 30,000 miles ago and i had to replace it and the clutch packs in the LS because they were chattering so bad.... Now the rear diff is chattering again when i go around corners... has anybod else had this problem? is it common with the ford 9.75 axles cause i have the 8.8 in my 99 and never had any trouble with it... whats the cause and solution to the chattering? any help would be great thanks
Mine would chatter while turning during long drives. Took it in to the dealership and they added friction modifyer (for LS diffs). The Service Manager told me Ford doesn't add enough modifyer at the factory. Haven't had any problems since. You can find the friction modifyer at most parts stores.
Hope that helps!
Hope that helps!
FORD does not make friction modifier, they buy it frome someone, so i would not worry about getting the "ford" brand. synthetics are supposed to be used in the rear axles, and the addative should be added to it. FORD recommmends synthetic in all the truck rear alxes these days. I have used the 75w90 instead of the 75w-140, but any synthetic brand, with the extra addative is the way to go.
Tectron1
04-10-2015 10:54 AM
rahach
1997-2006 Expedition & Navigator
26
02-22-2004 08:53 PM
