A couple of issues 96 aero
Gas mileage- new plugs, new maf, cleaned inj with techron milage still sucks. While looking around i noticed some wrench marks on the cps. Is there anyway to verify whether it has been changed?
Transmission- weird- when driving around town and it comes to a small grade or a slight change in throttle, the trans downshifts from 3rd to 2nd and shifts back to 3rd right away.
Engine cooling- never seems to get hot. temp gauge reads in middle and in the winter it takes forever to warm up.
any tips or suggestions greatly appreciated
thanks
ps whats seafoam?
thanks
ps whats seafoam?
Welcome 96bluegreen,
engine 3 or 4L?
mileage?
last time O2 sensor changed?
any codes?
2>3 shift...hold old is tranny ATF? last filter change? how old is vac. modulator if year is pre '96? change if either is older than 5 years or has more than 50k miles
change thermostat and coolant if older than 2 years...thermostats stick open on these....temp gauge is not accurate
Seafoam is a hydrocarbon engine cleaner that soaks and breaks loose carbon in combustion chamber and ring pack grooves...Berrymans B12 is about the same stuff
search Aero forum for Seafoam soak
engine 3 or 4L?
mileage?
any codes?
Hi
It's a 3.0 with 51k i bought used. So i don't know about any maintenance other that what i've done.
Do you know how many oxy sensors are on this thing? I went to buy 1 and they said there are 2 but i only found one in front of the cat, and i checked all the way back to the muffler.
thanks
thanks
engine 3 or 4L?
mileage?
any codes?
engine 3 or 4L?
mileage?
any codes?
build your own + free PC WindozeXP software click
2002 Ranger may be CAN system???
all OBDII scanner/code reader systems take same PC software basically....only 4 or 5 different diagnostic port plugs per car manuf.
shakenbake254
05-15-2016 03:08 PM
96inline
11-08-2015 08:59 PM
