Is it possible?
Old 09-22-2006, 10:43 PM
TheycallmeNASty's Avatar
TheycallmeNASty
TheycallmeNASty is offline
Is it possible?
Can I build a biodiesel processor capable of producing 20-30 gallon batches for under $500 because Im spending close to $300 a week for diesel to run my Excursion and I need out of this nightmare!!! Fabman if you are out there....PLZ HELP!!!u
Old 09-23-2006, 06:17 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Ok, Since you said PLZ, I'll help.............First a couple of questions, can you cut,weld, fabricate, etc? Do you have a shop to work in? Are you a good scrounger? If the answer to those questions is yes, you can build your own processer for little $$$$$$$. If the answer is No, than you are better off buying a processer kit. B-100 supply has them for under $500. Do you live in an apartment? If the answer to that is yes, you can forget brewing Biodiesel, it can be messy, smelly, and "tic-off" the management!
Let me know what you can do on your own, and if you have a good place to build, and run a processer, and I'll try and help you through this.
FABMANDELUX.
Old 09-23-2006, 08:03 AM
TheycallmeNASty
Yeah I live in a house and have some room to operate but I dont own a welding kit. I might be able to borrow one. Im mechanically inclined with a strong work ethic but Im no master fabricator. If when you say B100 you mean pure WVO then Im cool with that. However if B100 is a purveyor of processors and they have some quality processors for under 5 bones then maybe I should take a look. Would you mind posting a link? Hey thanks alot for any help Fabman!!!
Old 09-23-2006, 11:31 AM
cookie88's Avatar
cookie88
cookie88 is offline
B100 is pure biodiesel. It what you put in your tank after the WVO goes through the processor.
Fab already mentioned the addy, just didn't link to it. B100supply.com
Old 09-23-2006, 07:35 PM
Phydeaux88's Avatar
Phydeaux88
Phydeaux88 is offline
B100 is pure Biodiesel.
WVO is Waste Vegetable Oil.
Vegetable oil is the raw material used to make Biodiesel - they are not interchangable.
Old 09-23-2006, 09:21 PM
fabmandelux
If you haven't been here yet, you should check this site out: http://www.biodieselcommunity.org
FABMANDELUX.
Old 09-23-2006, 09:37 PM
TheycallmeNASty
Thanks for the input guys!!!
CharlyG
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
10-03-2016 04:06 PM
Foote86
Projects
05-05-2014 07:09 PM
davbell22602
06-17-2012 12:51 PM
AgentOrange
1997 - 2003 F150
10-01-2004 07:51 PM
debestuss
08-23-2004 09:23 PM
Quick Reply: Is it possible?
