B99 in an '06 LCF
B99 in an '06 LCF
Hello,
B99 is available at the pump here in Santa Cruz CA. and I've been burning it in my tractors for about six months now with no ill effects. I'm looking to buy a new box truck and Ford is discounting the '06 LCFs heavily. These trucks have a 4.5 Powerstroke diesel with twin turbo, it's basically a 6.0 minus two cyl. I understand ford only recommends up to b5, but will this truck run reliably on b99? Thanks
Prove it when you fill you tank with dino and pull into the dealer. What are they going to do, lick it? How about sending it in for $$$$$$ test to see what percentage is bio or dino? Hmmmm I think that is meant to scare you and protect them against things they do not understand. Stupid manufacturers
I agree, but I can't buy it in this area anyway, and don't have time to make it-so it's a non issue. It may be to protect them from people brewing their own that screw it up. I know the new trucks are very sensitive. I think my chevy has injection pressures in the neighborhood of 30k psi....
It really made me mad when I read it, but I bet Ford and Dodge are doing the same thing.
Stupid Manufacturers.
This is a good way to reduce our dependence on foriegn oil, and I can't even do it.
mgraveman, My buddy that is in on our bio project has ran approx 350 gallons of our homemade B-100 through his 05 durabuxx with no problem not even a filter change yet. I have run about 500 gallons through my 03 7.3 stroke. It runs a bit quiter and the old 7.3 IDI turbo in the M/H just loves it only about 300 gallons through it. No filter changes yet for mine......That said I water wash the heck out of my finished product and run it through two filter set up B-4 pumping into the vehicels. Kennedy is correct the stealership has to prove that the bio messed stuff up. If you are still nervious blend yours yourself 50/50 with petro for a few tanks and see how well it works. If you would ever have a problem that you think is fuel related just top off with petro D change out the fuel filter and take it to the stealership. But from my observations you will never have a problem........
