Pulleys? Need Help!
Pulleys? Need Help!
Ok I know someone knows the answer to this simple question. The dampner pulley on most Y-Blocks was a single sheave and if you added power steering to a car it would have a separate single sheave pulley which bolted to the dampner. I want/need to run a dual sheave dampner for a/c and Ford does in fact make one. I need to know will the p/s bolt on pulley still work with the dual sheave dampner?
Thanks Charles
Thanks Charles
Pulleys? Need Help!
I'm trying to find a setup that is factory that will mount the compressor above the generator and on the passenger side. I want the most compact system that Ford offered on the Y-Block. anybody have any ideas? I haven't had any luck at the salvage yards.
Thanks Charles
Thanks Charles
